Hey guys, I'm running new 3/16 copper nickel brake line and was wondering should I coil it near the master or leave it straight? I've heard of doing it both ways any thoughts?
Originally, my '58 F-100 had a hose from both master cylinders to allow for flex between the body and frame. When I replaced the brake lines, the hose was no longer available so I added a coil to the line as was the practice with the newer body-on-frame cars before things like ABS. The hose from the clutch master cylinder is still there.
Just an update. I finally finished the disc conversion. Here is what it looks like. Tell me what you think.<br/>Brakes work great.<br/>Thank you guys for all the advice.
Looks like you used thread tape? With the inverted flare fitting you don't require thread tape.
