Brake lines, to coil or not to coil?
Old 03-31-2017, 07:53 PM
Rusty 57's Avatar
Rusty 57
Rusty 57 is offline
Hey guys, I'm running new 3/16 copper nickel brake line and was wondering should I coil it near the master or leave it straight? I've heard of doing it both ways any thoughts?
Old 03-31-2017, 09:29 PM
'65Ford's Avatar
'65Ford
'65Ford is offline
It's nice to have some way of providing slack in the lines in case there's any flex between cab and chassis.
Old 04-01-2017, 06:05 AM
Walston's Avatar
Walston
Walston is online now
coil is best IMHO
Old 04-01-2017, 09:01 AM
dman2008's Avatar
dman2008
dman2008 is offline
Even if you only do 1-2 coils is better for flexing.
D
Old 04-02-2017, 11:34 AM
Rusty 57's Avatar
Rusty 57
Rusty 57 is offline
Thanks guys for the input. So should the coils be between the cab and chassis?
Old 04-02-2017, 06:17 PM
dman2008's Avatar
dman2008
dman2008 is offline
Right before the master cylinder.
D
Old 04-02-2017, 08:50 PM
Walston's Avatar
Walston
I usually just make a loop or coil just before it hooks to the master cylinder, unless there is a hose to provide the flexibility.
Old 04-05-2017, 06:19 PM
manglass's Avatar
manglass
manglass is offline
Originally, my '58 F-100 had a hose from both master cylinders to allow for flex between the body and frame. When I replaced the brake lines, the hose was no longer available so I added a coil to the line as was the practice with the newer body-on-frame cars before things like ABS. The hose from the clutch master cylinder is still there.
Lou
Old 05-21-2017, 05:09 PM
Rusty 57's Avatar
Rusty 57
Rusty 57 is offline
update
Just an update. I finally finished the disc conversion. Here is what it looks like.
Tell me what you think.<br/>Brakes work great.<br/>Thank you guys for all the advice.
Old 05-22-2017, 04:52 AM
Walston's Avatar
Walston
Looks great!
Old 05-22-2017, 07:17 PM
dman2008's Avatar
dman2008
dman2008 is offline
Just an update. I finally finished the disc conversion. Here is what it looks like. Tell me what you think.<br/>Brakes work great.<br/>Thank you guys for all the advice.
Looks like you used thread tape? With the inverted flare fitting you don't require thread tape.
D
trucktech
Modular V10 (6.8l)
03-03-2011 06:56 PM
kimble
11-09-2010 04:25 PM
ShowdownAutodotcom
1997 - 2003 F150
11-07-2009 05:53 PM
rvpuller
Modular V10 (6.8l)
11-21-2008 08:32 PM
PA F150 4X4
04-06-2006 01:29 PM
Quick Reply: Brake lines, to coil or not to coil?
