Best aftermarket exhaust?
Looking to put a new exhaust on my 1993 7.3 idi. Other than a lift the truck is all stock. It is originally from factory a non turbo engine but I have a good stock turbo and all the needed parts that we will be putting in the near future. What size and brand is a good one to go with? Not looking for stacks, don't want to be cutting holes in my box and straight piping it isnt an option either. Also, anything else I should be considering when putting a turbo on the motor? Already have the boost and egt gauges ready to go in with the turbo
From Summit:
AP Exhaust 300A7514 - AP Exhaust Straight Exhaust Tubing
Exhaust Tubing, 3.00 in. Outside Diameter, Straight, 7.5 ft. Length, 14-Gauge, Steel, Aluminized, Each
$22.97
Walker Exhaust 41434 - Walker Exhaust Elbows
Exhaust Tubing, 90 Degree, Elbow, 3 in. Diameter, 6 in. Radius, Steel, Aluminized, Each
WLK-41434
$17.97
AP Exhaust AS300 - AP Exhaust AccuSeal Exhaust Clamps
Exhaust Clamp, AccuSeal, Butt Joint, Band Clamp, Steel, Aluminized, 3.00 in. Diameter, Each
APH-AS300
$5.27
Walker Exhaust 35103 - Walker Exhaust Hangers
Exhaust Hanger, Steel, 9.5 in. Long, Clamp-On, Universal, Each
$7.97
Summit Racing SUM-630854 - Summit Racing® Glasspack Mufflers
Muffler, Glasspack, 3.00 in. Inlet, 3.00 in. Outlet, 12.00 in. Overall Length, Steel, Red, Each
$20.97
You could go with a 2' long muffler for $2 more if you want it quieter. Should be under $100 all in.
$22.97
WLK-41434
$17.97
APH-AS300
$5.27
$7.97
$20.97
If you put the stock factory turbo on it, just straight pipe it. Go with the stock 2.5" exhaust back and call it good.
Just make sure to run the exhaust all the way back and out. It's much quieter if it exits out from under the truck.
Also, adding the hump over the wheel will do some quieting as well.
The turbo(especially the stock factory turbo - Banks trucks are a lot louder) quiets it down a heck of a lot.
If you run it NA, get a through-flow glasspack type muffler. I used a Jones "Full Boar" muffler, and it worked quite well on my other truck.
SilverBullet131313
26
06-04-2009 08:24 AM
