1952 F3
Old 03-29-2017, 06:25 PM
pineconeford's Avatar
pineconeford
pineconeford is offline
pineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant future
The rear end (if original) is likely to have 4:86 gears. Not bad for real truck usage...but not so good when keeping up with modern traffic. Top speed is about 45 mph.
Take a picture of it from a few angles and these guys can identify it in no time.
Old 03-29-2017, 06:29 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
The stock rear is a Timken model 51524 having a 4.86/1 final drive ratio. Top speed without wrapping out the 390 will be about 50 mph. And you'll notice it in the gas mileage. A later axle with 3.54 or 3.73 gear set is a common swap to yield road speed and reduced RPMs.
The steering column is also shared with an F-1. Stu
Old 03-29-2017, 06:31 PM
pineconeford
Also looks like you have two front bumpers laying in the bed. The one with top & bottom ribs is correct for 51/52.
Rear bumpers are almost impossible to find since Ford didn't provide them when new.
Old 03-29-2017, 06:36 PM
pineconeford
I just keep looking at your pictures...thanks again.
The printed weight ratings on the bed sides are a cool feature to re-create when you paint it. That truck may have been born as a fleet duty rig.
Did you get any history from the previous owners?
Old 03-29-2017, 07:49 PM
Nick Olsen
Nick Olsen is offline
Nick Olsen is starting off with a positive reputation.
The 67 thru 72 f250 have those gear sets?
Old 03-29-2017, 07:53 PM
Nick Olsen
I hadn't talked about its history really with the last owner, I guess that's something to ask when I pick it up. I had looked around for early 50's ford for awhile. This was the first one I saw that wasn't completely rusted out. So I guess I overlooked a few things
Old 03-29-2017, 08:03 PM
truckdog62563
Yes. The donor's data plate will have the axle code, and commonly there is a tag or gear count stamp on the casing. Stu
Edit - I suspect you know of yards in your area, but if you need to venture a little further out I know that Stutesman's in Casey is a good yard, as is Johnson's in Norris City. Stu
Old 03-29-2017, 08:25 PM
Nick Olsen
The closest decent ones are all about 2 hours away from me, I do come up that way now and again. Might take a look next time I head up that way. Thanks!
Old 03-30-2017, 01:07 PM
Nick Olsen
I'm thinking about going to a few salvage yards today. Thinking about trying to find a rear end, what would be a decent price for one? The salvage yards around me seem to be high, but I've never had to purchase one so I don't know exactly.
Old 03-30-2017, 01:23 PM
truckdog62563
Must defer to others. Have kept mine stock Timken, but did switch mine to a reproduction 4.11/1 ring/pinion set available from Chuck's Trucks. A yard Dana 60 will be a cheaper fix. Stu
Chucks Trucks LLC., Chuck's Trucks, Chucks Trucks
Old 03-30-2017, 01:37 PM
Nick Olsen
All 68 f250 that's being parted out, about ten minutes away from home. Did all 68's have the Dana 60?
Old 03-30-2017, 01:58 PM
truckdog62563
Pretty sure so, it was the stock offering. Below are identification charts and a listing of Dana Bill of Materials Codes. The BOM will be on the axle to let you know what you are getting. . Stu
Differential Identification | West Coast Differentials
What rear end ratio is in my Ford , do I have positraction? - Drivetrain
http://www.therangerstation.com/tech..._1967-1978.pdf
  #28
Old 03-30-2017, 05:26 PM
1952henry's Avatar
1952henry
1952henry is offline
1952henry has a good reputation on FTE.1952henry has a good reputation on FTE.1952henry has a good reputation on FTE.
Did you determine what rearend yours has? If not sure, post a picture. And welcome. Glad to see another 3/4 tonner saved.
  #29
Old 03-30-2017, 05:54 PM
truckdog62563
Good point, don't assume to p.o. didn't already swap it despite his statements to you that he did not. He went to the trouble of dropping in the big 390 and three speed, would have made sense to do the axle too. Stu
  #30
Old 03-30-2017, 11:52 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Scotty's 52 F3 is offline
Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.
Welcome to the forum. I posted up a lot of pics and details of everything I've done to my F3. Search my posts and feel free to ask any questions.
Quick Reply: 1952 F3
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
