Let's see if I can get a better response here!
  #46
Old 04-02-2017, 09:57 PM
tormentedfaith's Avatar
tormentedfaith
tormentedfaith is offline
heres the blow by that it has.
  #47
Old 04-02-2017, 09:58 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,180 Likes on 811 Posts
Did the injectors ever get O rings on service records you have? If not I would change them out and see if it helps some. But judging for the last video by bet is that the at least one injector is bad, you can check for injector armature clearance , all you do is remove the injector solenoid, and fit a .004 filler gauge should fit loose but not to loose if it's a good injector 003 filler gauge should fit tight anything below that you have a bad injector, but you can always shim them to save some dough for when you decide to buy injectors.
  #48
Old 04-02-2017, 10:01 PM
tormentedfaith
Originally Posted by z31freakify
Did the injectors ever get O rings on service records you have? If not I would change them out and see if it helps some. But judging for the last video by bet is that the at least one injector is bad you can check for injector armature clearance , all you do is remove the injector solenoid, and fit a .004 filler gauge should fit tight if it's a good injector .003 filler gauge should fit tight anything below that you have a bad injector, but you can always shim them to save some dough for when you decide to buy injectors.
thats the one thing he "said he did" but I'm kinda doubting. that's the one record he doesn't have. So I'll try injector o rings and look into the shimming and gauge you're talking about. Thanks so much for your help!
  #49
Old 04-02-2017, 10:05 PM
tormentedfaith
is there anything I should do with the injectors while they're out? Good thing is the dieselorings.com guy is right down the road from me haha
  #50
Old 04-02-2017, 10:08 PM
z31freakify
If you have the $ send them out for a flow test, but if it were me upgrade time lol...
  #51
Old 04-02-2017, 10:18 PM
tormentedfaith
if it was up to me I'd just get new ones. But the wife will kill my ice already put more money in this thing than I wanted lol
Blackened88
05-17-2017 12:51 PM
dburress
1999 to 2016 Super Duty
01-29-2011 09:15 PM
Bigfwt04
21
12-17-2008 10:52 AM
John8172
3.8 & 4.2L V6
07-10-2002 09:14 PM
Quick Reply: Let's see if I can get a better response here!
