Undercoating Suggestions
Old Mar 28, 2017 | 11:18 AM
pezsox's Avatar
pezsox
I am going to undercoat the bottom of my cab (possibly the wheel wells) and I was wondering what specific product you would suggest. I have the cab off of the frame right now, so I figured now is a perfect time to lay it on its back and get all the nooks and crannies. I have looked at Por15, Bedliner materials (roll on / spray), Krylon Hammered, etc.. I would love this groups thoughts.
Old Mar 28, 2017 | 11:23 AM
hulleywoodworking's Avatar
hulleywoodworking
I haven't tried it yet, so I have no experience with it, but the bedliner SPI sells gets used alot for undercoating. It also gets used for sound deadening on inside of door panels. If you go to their site, Southern Polyuerthanes, Inc. , and go to the forums, there is a section devoted just to their bedliner. It answered all of my questions.
As I have been using their primers and clear coats and find them to be excellent products, I plan on using their bedliner as undercoating/sound deadener when I get to that point on my build.
Old Mar 28, 2017 | 11:44 AM
burnettd01's Avatar
burnettd01
Thumbs down Undercoating
I did the floor, firewall inside and out, and underside of the cab with Lizzard skin heat control and sound deadner.
It's expensive but helps a lot. I plan on using a two part epoxy bedliner called T-Rex on the running boards and inside the fenders.
If it looks good, I will probably do the bed as I am doing a metal floor - not wood.
Hope this helps
Dan
Old Mar 28, 2017 | 02:31 PM
CharlieLed's Avatar
CharlieLed
Sandblast or scuff the existing floor (if the paint is in good shape). Spray the floor with a good DTM primer, 2 coats. When dry scuff again and apply UPOL Raptor or other two part bedliner...here is what it will look like
Old Mar 28, 2017 | 05:09 PM
jniolon's Avatar
jniolon
old and in the way
I used a product called Monstaliner Monstaliner do-it-yourself roll-on truck bed liner outperforms Herculiner Bed Liner, Duplicolor and Rustoleum Road Warrior. Comes in lots of colors and is a nice thick rubberized coatings... goes on with a roller and brush and looks great...
I wanted the yellow to blend in with my exterior color Millennium Yellow
j
Old Mar 28, 2017 | 09:40 PM
BTclassics's Avatar
BTclassics
How do you plan on applying? Ie. Do you have a paint gun that can handle undercoating/ bed liner? If so, there are a lot more options. The tintable bed liner products are pretty nice if you want to match body color.
I went rattle can and liked how the 3M Professional Grade Rubberized turned out. It was more expensive, but it was a little smoother than the Dupli-Color version. Both were better than one I picked up at a swap meet that was pretty gloppy had more of a brownish tint to it. The bed of my truck has a spray can Rust-Oleum Truck Bed Liner. It is a more textured finish (not rubberized) and seems pretty durable.
Old Mar 28, 2017 | 09:52 PM
CharlieLed's Avatar
CharlieLed
Here is a deal for the whole kit, all you need is the compressed air source:
Amazon Amazon
Tintable is also available and will work just as long as you have some of the original paint/tint to add to it. Not too many people crawling around under your truck to see if the underfloor matches the outer paint color though.
Old Mar 29, 2017 | 03:54 PM
petemcl's Avatar
petemcl
Some good suggestions. I like the Raptor product Charlie. I wish I had known about that several months ago. After clean and prime I just used rattlecan Krylon Truckbed black. It dried very hard and the bond seems solid.
Old Mar 29, 2017 | 07:54 PM
rusty48's Avatar
rusty48
Ive used both rattle can bed liner and undercoating, If I had to say the only difference is the undercoating seems to be a little thicker softer. Maybe better for sound and rock dents. I like that raptor stuff, May give it a try once I get to the flooring repairs on mine.
Old Mar 30, 2017 | 06:35 AM
CharlieLed's Avatar
CharlieLed
The Raptor hardens pretty well, if you use it (or any other coating for that matter) be sure you scuff up the panel well prior to spraying to give the coating some tooth to grab onto. Here is my 40 Ford coupe floor that I coated in the same manner as the 56 F100 pictured above.
Old Mar 30, 2017 | 08:22 AM
48 Steel's Avatar
48 Steel
I used Permatex Heavy-Duty Rubberized undercoating. To help eliminate "stars" in my fenders I applied 1 can per fender.
Old Mar 30, 2017 | 03:19 PM
fking1's Avatar
fking1
Used a 3M undercoat in a rattle can.
Easy to spray on and works good.
Old Mar 30, 2017 | 04:44 PM
pezsox's Avatar
pezsox
these are all great recommendations. I was almost to the point of just using a Krylon Black, then these liners came into play. Now I am more confused. I am only doing the undercab for now, I just want to get this cab back on the frame. I have an air compressor, but that is it.
Old Mar 30, 2017 | 05:31 PM
schoo's Avatar
schoo
I used the t- Rex bedliner sprayed on, if you use a liner or undercoater I would recommend masking at the connection points this stuff can be thick
crucialprospect
Mar 31, 2018 03:24 PM
Sarge513
Jun 4, 2007 06:05 AM
ksmith203
Dec 11, 2006 07:57 AM
TheImpaler
Jun 7, 2003 02:42 PM
freeky1
Sep 14, 2002 01:03 PM
