OBD port GPS dongle
Old 03-27-2017, 12:15 PM
aerostarmark's Avatar
aerostarmark
aerostarmark is offline
Question OBD port GPS dongle
I was wondering if Ford has any safety concern with aftermarket GPS dongles connected into the OBD port of their vehicles?
Is there any evidence of a OBD GPS dongle affecting the safety of a vehicle WHILE it is being driven?
The OBD port provides information on a car's inner workings, and these dongles would at least indirectly connect the Internet to the CAN "bus," which shuttles information to the electronic control units (ECUs) that control the brakes, steering, transmission and other systems.
The port is simply meant to convey diagnostic trouble codes to a car owner or mechanic. Likewise, most cars' internal networks were never supposed to be connected to the Internet, and as a result, have loose or nonexistent security safeguards.
What happens when the device is connected to the vehicle while the vehicle is in operation? Could the vehicle — or specific Electronic Control Units (ECU) — shift automatically to diagnostic mode?
This could have an impact on how data traffic is prioritized on the CAN bus which could cause the vehicle to malfunction because the priority might not be given to specific data as it would if the vehicle was set to normal driving mode.
To the extent that the dongle may cause the vehicle to shift to diagnostic mode and to perform in a way that is unsafe for the use of the vehicle on public road, then there is a serious safety issue.
I have some concern over the safety of these units being installed on a fleet of Ford F250's (2005-2015) at my place of employment.
Any info you have would be helpful.
Thanks
Old 04-02-2017, 02:21 PM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,076 Likes on 978 Posts
Me thinks that is better answered by the vehicles manufacturer. As far a I know... there shouldn't be a problem with that...BUT....
Old 04-08-2017, 08:36 AM
GABAR's Avatar
GABAR
GABAR is offline
Thanks
I don`t think it would cause any problems considering that mid year, Ford will be offering the Smart Link module that will connect via the OBD-II port and this module will enable older models of Ford to have the same Ford Connect features as many of the 2017 vehicles.
I don`t recall the service provider but I think Ford said it`ll be Verizon and they`ll use the Ford Pass App which requires a constant internet connection.
Hope this helps you with your concerns.
Old 04-13-2017, 01:43 PM
01 GT F150's Avatar
01 GT F150
01 GT F150 is offline
It would also be able to relay speed and driving styles I.E. TPS RPM's and of course position. Kind of like a babysitter that they can use to write people up or fire. To some thats not an issue but if your under the gun and have to go go go they don't realize what it takes to do what they expect. They hide the agenda by saying it's to monitor engine codes and such.
aerostarmark
03-27-2017 12:17 PM
Firefighter 1406
07-19-2010 02:55 PM
Pablo-UA
Aerostar
06-29-2008 02:50 AM
wild ford child
General Automotive Discussion
01-09-2008 03:49 PM
Riso79
1997 - 2003 F150
09-10-2002 02:02 PM
Quick Reply: OBD port GPS dongle
