Crown Vic 4 wheel disc brake conversion
Old 03-27-2017, 07:33 AM
knucklecars's Avatar
knucklecars
knucklecars is offline
I have done the Crown Vic front end swap and the crown Vic 8.8 rear swap....all went very well , now doing brake lines
I have mounted the Crown Vic booster and master cyl also but the car had antilock brakes and no proportioning valve
For those that have done this swap what proportioning valve did you use for a 4 wheel disc brake setup?
I have read that some didn't use one which makes no sense as you need a distribution block of some sort to run the lines from the master cyl
Any advise would be welcome
Thanks!
Old 03-27-2017, 09:16 AM
6t6merc's Avatar
6t6merc
6t6merc is offline
Not CV swaps so you might not care, but when going from drum to disc I have used Wilwood adjustable prop valves with success.
Old 03-27-2017, 12:01 PM
knucklecars
Thanks...the issue is the 4 wheel disc brakes......and I need a distribution type proportioning valve to distribute to the two front lines and to the single line feeding the rear.
the aftermarket ones I see just go to back lines
Old 03-27-2017, 03:48 PM
TheMonson's Avatar
TheMonson
TheMonson is offline
Old 02-14-2018, 05:20 PM
black97roush's Avatar
black97roush
black97roush is offline
well what did you end up using to make work
F100-1969
37
03-31-2018 10:25 AM
VENNM
General Automotive Discussion
07-24-2014 11:25 AM
hotrod351
1966 - 1977 Early Broncos
04-25-2013 12:50 PM
1972RedNeck
06-18-2012 10:05 PM
mt54
15
11-05-2008 08:03 AM
Quick Reply: Crown Vic 4 wheel disc brake conversion
