Cab mount rubber bushings.
Friend of mine got tired of the same runaround not interested vendors just went to the wrecking yard cut the floor out of a wrecked late seventies Chevy pickup welded in a portion of it in with those cab mounts new rubber mount for those years are cheap and plentiful probably doing rust repair any way.
These fit
seacar, you do yours yet?
I also received the universal mounts but have not received my cab yet. Considering the deformed mounts that came off, I think the universals will work just fine. No bolts came with the new mounts. All of my front end has been disassembled so I'll be looking forward to hearing how yours lines up. Keep in touch.
Cab mounts
Absolutely no company would provide any help on this one. With a diameter 2.5 inches, height 1.25, hole .75 inch, provided by member idaho211, I located bushings that I think may work. They were made by Energy Suspension but since they were of no help, I purchased them through Jeggs. Part #355-9-4102G. I have not received them yet. I should know later on this week. They are called universal mounts.
So I been searching through these old post I will say a lot of good info here!!
What makes the size of the 4X4 mounts different then the 2WD mounts?
Reason I ask is I have a 59 2WD that the floor boards were shot on but the rest of the cab was great I found a 4X4 cab that the floor boards were in much better shape than the one I had but the roof of the cab had some major issues. I separated both the upper cabs from the lower section and repaired the better of the 2 floor boards (the 4X4 floor) and will be putting the top part on the opposite floor board.
I am keeping the same 2WD short bed frame. One thing I noticed about the 4X4 frame is it has more support in different location then the 2WD one.
So is it the cab supports that are different or the frame? or something else?
I bought a set of the carpenters for 2wd and they look to be the same. I’d do a photo comparison but I already shoved the rears under the cab as I work on the front. Where I think the 4wd set is different is the rad support arrangement on the 4x4. Some one can correct me if I’m wrong. I’m still thinking of a 1 or 2 inch body lift as well.
F250racer
09-18-2010 09:22 PM
