Holley Pro-Jection on 390?
Has anyone done this? I like my motor craft carb, but with this being my daily driver, I put more than 20k on this truck a year, & I want to at least try it out, I already have the 2D throttle body, so I would just need a pump, wire harness and an ECU, if I'm correct. has anyone done this on their 390? or any FE, how did it work?
well when its -45 out I think ill be glad to have the fuel injection instead of the carb, this winter it took me 3 tries to get it started once i think, carb and engine are both in fine condition, but when its any colder than -20 that cold start is a bitch and always takes a couple tries
http://www.arctic-fox.com/fuel-fluid-warming-products/in-line-fuel-warming
In-Line Fuel Warming
In-Line fuel warming is a proven, cost effective method of providing protection against stall-outs due to fuel waxing. Obtain the margin of safety you need in moderate cold weather temperatures with In-Line Fuel Warmers from Arctic Fox. In extremely cold weather operation, In-Line Warmers may be combined with In-Tank Fuel Warmers to provide additional protection.
Installation is accomplished by simply routing fuel and coolant lines to the unit. Heat is exchanged inside through a series of stainless steel tubes to provide efficient fuel warming. In-Line Fuel Warmers are available with and without mounting brackets and fuel temperature sensing, coolant shut-off thermostats.
By positioning the unit close to the fuel filter, you are obtaining maximum fuel warming efficiency and preventing costly fuel freezing and clogging at the filter. An advantage of In-Line Fuel Warmers is the flexibility of mounting applications.
Arctic Fox has an In-Line Fuel Warmer model to fit applications from forklifts and passenger cars to construction and mining equipment. Arctic Fox In-Line Fuel Warmers are compatible with Diesel Fuel, Diesel Fuel Additives, and there are models available to operate with B-100 Biodiesel as well.
For more information, download our full line Product Catalog, or go the "Product Information" section to see product data sheets, installation instructions and other information to help with your decision making.
does anybody know if a TBI unit off of a 1991 chevy silverado can be hooked up to the holley projection 2d system? they look identical, & I already have the chevy TBI, i just need the o2 sensor, wire harness, computer & fuel pump. is the 2d the same exact thing as chevy's TBI's they used all those years?
1965kale, that is the best news I think we all have heard. Piecing a system together I think is just asking for issues and if used as an every day transport its not what I would do.
Dave ----
well, Im sure the GM TBI would work the same as the holley TBI, but I would rather not use the analog system from the far past. Im really liking the looks of this FI tech TBI, Im looking at running the 40003 with the fuel command center, so I can eliminate the need for a return line, and can therefore keep my perfectly functioning dual tanks withought altering any of that. Im still not entirely sure how that fuel command center works though, it dosnt make sense too me yet. but I really like the Idea of the whole system. would suit me just great, the only downside is I need to find a 4 barrel intake manifold for my 390
well, Im sure the GM TBI would work the same as the holley TBI, but I would rather not use the analog system from the far past. Im really liking the looks of this FI tech TBI, Im looking at running the 40003 with the fuel command center, so I can eliminate the need for a return line, and can therefore keep my perfectly functioning dual tanks withought altering any of that. Im still not entirely sure how that fuel command center works though, it doesnt make sense too me yet. but I really like the Idea of the whole system. would suit me just great, the only downside is I need to find a 4 barrel intake manifold for my 390
Your stock carbureted fuel pump (or a TBI low pressure EFI pump) feeds low pressure fuel to the FiTech Fuel Command Center’s sump tank.
A reservoir of fuel is in the sump tank at all times so the 340 L/PH pump inside is submerged in fuel. The sump tank contains a float that automatically shuts off the fuel coming into the Sump Tank when the correct fuel level is reached. At that point the stock pump is dead heading against the Fuel Command Center just like it normally would against a fuel pressure regulator.
When the engine is running the Fuel Command Center pump supplies high pressure (58 PSI) fuel to the EFI throttle body.
____________
Consider the Edelbrock Performer PN 2105 or Performer RPM PN 7105. Starts at about $340 nowadays...
Alternatively, an OEM "S" code FE intake for around $100 to $150. Edelbrock Streetmaster is another alternative although prices are climbing for vintage FE intakes... like $200 to $250.
And as an FYI, ... an aluminum intake weighs around 22 pounds... an OEM intake is around 80 lbs.... What is equivalent to about 60 pounds in the real world? A bag of QuikCrete concrete!!!! Ever lift one?
