Lift question, Something is off... What's the fix?
Ok - you can see the linkage with the baby blue tape, angle is different.
You need an adjustable track bar to center the axle under the truck, your track bar is at a pretty strong angle and pulling the axle towards drivers side as the lift and angle have effectively shortened the functionable length of the track bar. The other possibility is that the lift needs a different track bar mount, dropping it by 4 inches which is a better solution and probably cheaper than an adjustable track bar.
Then you need to center the sway bar in its mounts on the frame.
Did you install a lift for a diesel on a gas truck? I suspect you have a very healthy 4 inches of lift
That kits does not come with a modified track bar mount or an adjustable track bar - the kit replaces the OEM track bar with theirs mounted to the OEM mounts at axle and frame. If the shop did actually install the Zone Track bar then the shop needs to center the sway bar into its mounts properly.
