AL4D Tranny Troubles (HELP ME!!) - Ford Truck Enthusiasts Forums
Old 08-31-2003, 12:00 PM
budbaringer budbaringer is offline
budbaringer is starting off with a positive reputation.
Help!!!!!
I overheated an AL4D in a 93 4.0 Ranger 4x4 towing a bassboat, it slipped and fried the clutches. Trying to save myself the $1600 REBUILD on a truck thats been wrecked and is not monetarily worth much, (but I hate to junk it cause functionally everything else works good) I bought a used tranny from a salvage yard. After installing and changeing fluid, (flushed coolers and torque converter as good as I could several times manually) new filter and fluid, droped it down fired it up and put it in reverse to back out the garage and it went forward
Checked linkages and even disconnected and worked it by hand, no matter where its at the tranny seems to be stuck in first gear, even in park it tries to fight the parking pawl. I pulled it out of driveway and drove down the road hoping something was just stuck and would work loose, no luck. It shifts from first to second but then will drop back to first and does not shift up after that. Back up it went and I pulled it back out, salvage yard is now "trying to find another one" am I farther ahead getting this one rebuilt and fighting to get my money back, or is changing over to a manual tranny a logical alternative? any and all help will be appreciated.
I Have never tried to rebuild an automatic myself and from what I here the AL4D is a real bear to work on, Is rebuiling it myself an option that is logical or would it not be a wise attempt?
Old 09-04-2003, 08:50 AM
93texexp 93texexp is offline
93texexp is starting off with a positive reputation.
Actually the A4LD is not that bad to work on. I just rebuilt an A4LD out of a '93 Explorer and it works great. It cost me about $500 to $600 (I really don't want to look) including having the torque converter rebuilt. A good place to get parts is Transtar Industries if they have a distributor in your area. Get the ASTG manual (about $15 - $20) and follow the instructions, they're very detailed and easy to follow and you don't need any specail tools.
This is a good website for some tips and links:
http://www.geocities.com/MotorCity/Flats/3349/a4ld.htm
I bought some of my parts from:
www.bulkparts.com
Stuck in Park...HELP PLEASE!!! mastercrack61 1978 - 1996 Big Bronco 5 12-04-2014 11:41 PM
Ford C6 weird problem. Please help Louisenslin Clutch, Transmission, Differential, Axle & Transfer Case 0 12-01-2012 04:36 PM
e40d forward in park and reverse deadendcustoms Clutch, Transmission, Differential, Axle & Transfer Case 2 07-22-2009 01:29 PM
Help! Stuck in Parking Lot: Can't Shift into Gear. Linkage? kpwall 1987 - 1996 F150 & Larger F-Series Trucks 2 05-25-2007 04:59 PM
E4OD REBUILD??? trannyhell Clutch, Transmission, Differential, Axle & Transfer Case 1 07-02-2001 03:40 PM
Tags
94, a4ld, al4d, astg, c4, codes, filter, ford, kit, manual, ranger, rebuild, rebuilding, reverse, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
