351w MARINE motor into my Van? Good Idea or Bad?
I burnt the piston rings in my 1996 351w E250 van from overheating and I've been looking for another motor. I talked with a guy that says he has a 1977 351W Marine motor with low hours in great shape for$600.00. he said it's regular rotation.
1. Will this work in my van. The van that I use for work installing windows and towing a 5x10 enclosed trailer.
2. Is this a good idea or should I look for an automotive motor?
Thanks for any advice.
on
With all the marine stuff stripped of you will find the same old 351w longblock underneath with the exception of the heads.. should be GT40s or a similar casting, and the cam. The heads won't affect your swap but the cam will so it would likely have to change, and that will be a flat tappet cam where the original motor in your truck had a roller cam so the distributor drive gear also has to change.
Uni Moe
09-18-2014 09:19 PM
Old93junk
11-15-2010 10:39 PM
78 Ranger
11-21-2005 08:17 PM
