I have a 1977 F-250 Custom with a big block 460 and a C6 automatic transmission. There are three main problems that I've been having with it.
1. It has a hard time turning over. It tries, but I have to hold the key down for a few seconds and give it some gas for it to start.
2. When I back it out of my driveway, it dies on the way down. But it runs ok once I take off in drive.
3. This one is rare, maybe two or three times a day. I'll be sitting at a stop light, and when I push on the gas, it takes off very slowly and gradually. I can have the pedal on the floor and it only gets up to about 5mph by the time I hit the end of the intersection. The engine revs up like normal, but the wheels take forever to get going. It speeds up like normal after a while, but not at the start.
I'm relatively new to car stuff. This truck was my first project. With that being said, I have no clue what's wrong. Any information is very much appreciated.
Clean the start circuit terminals, battery hot, battery ground, and everything that connects to the starter solenoid.
These trucks are "ground deficient" in my opinion. I'd add extra grounds:
1. Bed to frame
2. Cab to frame
3. Core support to frame
4. Engine to cab (should already have one btwn the firewall and intake manifold).
... it sounds so me some carburetor adjustments and choke adjustments are necessary... the stall, slow acceleration, and hard-to-start. Adjust the float level, initial choke setting, and make sure the choke system is working.
1) if your primary cables are original or cheap parts-store cables, it's quite possible they're not carrying enough juice. If you don't know the condition of your cables you could ohm them out, but probably better to just get new cables-battery to solenoid, solenoid to starter, and block to battery ground. Also, you need a suitable battery with plenty of CCAs. I like the group 27f
2) Starts then stalls when cold...possibly choke
3) Revs up but truck don't go...that's transmission. Try changing the fluid, and flushing the lines. Possible that's it's just low on fluid...but get it fixed-they're expensive when they break
Our trucks are not your neighbors' Corollas where one just turns the key and it goes. We have to kick the pedal a coupla three times to set the choke (if you're running one), turn 'er over for a few seconds....then mebbe hit the pedal a few more times whilst she's turning over before she'll start. Would you explain "A hard time turning over?" Are describing a hard time cranking? If so, that would be the electrical connections, as previously stated.
She's still cold...and the choke needs to be set for her to warm up properly. After a good five minutes of warm up, punch the pedal to open the choke...if it's set right.
Definitely transmission fluid low...or mebbe too late for the C6 fill the to proper level....now it's trans teardown time. Use type F.
ALSO.....get yerself a DVOM, a vacuum gauge and timing light. Just to name a few indispensable tools for working on these vehicles.
The C6 fluid is measured when the vehicle is warmed up and you ran through the gears, yes? Fluid too high is worse than too low! Correct the problem quickly!
Be careful when judging the C6 dip stick, It will read way low if its cold and not running and you may interpret it has having way too much if its showing a light residue on the stick above the arrows..... Its a PITA to really pin down where its at...... I can tell when its really low you will know, because it wont go into gear....
Get back to us after the C6 fluid level is right.
Agreed-too much fluid is worse than too little fluid
There's no shame in getting a second opinion. Take the truck to an oil-change place, and ask them to check (and show you) the dipstick. It's hard to reach anyway, so just tell the guys you couldn't reach it.
Stop in when they're not busy, and they'll likely check it for free. Whenever I go, the guys love seeing and talking about these great trucks. And they've all got a story about them...
I realized today that sometimes it won't downshift to 1st gear, so it's trying to take off in 2nd. This is what's causing the slow takeoff. Anyone know why it decides not to downshift sometimes?
I know, I'm a moron. I just realized I've been driving the truck with the transfer case in 4HI with the hubs unlocked. Could this have caused the slow takeoff by any chance?
