OK so I'm afraid of the CAT scales
Old 04-02-2017, 02:05 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,074 Likes on 976 Posts
u..or if there isn't anyone else waiting you can always drop the RV behind the scale and just weigh the truck axle by axle first... then hook up and reweigh the rear axle of the trick to get the pin weight ( with math) and then get the whole rig and after that just the RV.
Old 04-03-2017, 04:27 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,085 Likes on 1,778 Posts
Question, if doing axle by axle and using a WD hitch what does that do to the axle weights?
Should you remove the WD bars and weigh the cobo so you know just what is going on?
Dave ----
Old 04-03-2017, 04:45 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
Dave ----
Good idea as a baseline, IMO.
If you're wanting pin weight, weigh out the pickup bobtail. Doing the axle method. Then hook it up to see how the weight weighs.
My pickup weights about 5,200 on the front axle and 3,700 on the back axle, when empty.
Old 07-07-2017, 05:09 PM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is offline
Thanks everybody... update went and weighed my truck and boat. Only hiccup was when I went back for the reweigh they asked why i was reweighing five minutes later....I thought the reweigh was so they could average the two weighings....oh well. LMAO
Old 07-10-2017, 08:57 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
You should have seen the looks I got when I weighed a Hyundai Accent all by itself Nice setup
Old 07-11-2017, 03:00 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
should have seen there faces .. in 1969 , weighting a 1965 Impala SS 409..
to adjust weight bias..
they still took my money...
Old 07-11-2017, 03:30 PM
urbex's Avatar
urbex
urbex is offline
I've been meaning to get the weight of my car hauler trailer for some time now, and I'm thinking attempting to unhitch/hitch up the trailer on the scales will likely be frowned up.
If I weigh the truck empty, then with the trailer on the reweigh, would it be correct to subtract the empty rear axle weight from the loaded weight to get the pin weight, then add that pin weight to the trailer axle weight to get the trailer weight by itself?
Old 07-11-2017, 03:45 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
if you subtract your empty truck weight from your total weight, you are left with your trailer weight
Steve
Old 07-11-2017, 03:50 PM
urbex's Avatar
urbex
urbex is offline
You can't see it, but I am quite literally face palming right now. I seem to like to over complicate things, lol.
Thanks, RV_Tech!
Old 07-11-2017, 04:01 PM
Chuck's First Ford
you could weight truck & trailer ... move to parking area..
disconnect trailer..
weight truck.
collect paperwork
reconnect trailer.. and go home.. or ?
Old 07-11-2017, 04:15 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Thanks, RV_Tech!
we all do it. No big deal,
Steve
sirkingdra
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-27-2017 02:07 PM
wrvond
04-28-2016 11:34 AM
69 and 85
Iowa Chapter
04-12-2005 08:06 PM
Stanstruck
Ohio Chapter
06-30-2004 08:11 AM
Quick Reply: OK so I'm afraid of the CAT scales
