Tires: Brand Opinion, Size, Rubbing, & PSI
That's what I was thinking! Just put a custom drop hitch on the "Brodozer" and you would have the best of both worlds, still driving a Ford 6.7 and never get stuck during hunting season.
The truck I recently bought has Nitto A/T Terra Grappler G2 295/65/20 E-rated tires. They look fairly new, so I plan on running them for a while. Does anyone have experience with these? Is this a size that some of y'all are running? I was getting the "low tire pressure" message, so I checked them. Three were at 55 and one was at 50. Tires show 80psi max, so I filled them all to 78-80psi. Opinions on psi with these? Also, my driver's side is rubbing the sway bar, which I assume would be normal for tires of this size, but I want to confirm that? Or is my sway bar slid too far to this side?
It is my understanding that the threshold for the TPMS sensors is set at 75% of the recommended 65 psi front and 80 psi rear pressures (F-350). I like to run my rears lower than my fronts when unloaded so I retrained the system and told it that the fronts were in the rear and the rears in the front. I aired down to 80% of recommended which puts me at 64 psi for the front tires and 52 psi for the rears.
anthonym92
08-22-2017 10:03 AM
f150cobrajet
10-22-2002 07:20 AM
