Am I the only one that can't stand the traction control system?
How do you guys turn off traction control? I just got a 13 6.2 and I HATE the traction control while I'm plowing. Every time I turn it off it comes right back on in no time. It drives me crazy. I've gotten stuck a couple times because of it during this past storms and I haven't been stuck in a couple years. I absolutely hate the tsc system. I even would hold down the button until it said advance Trac was off and within a few passes everything f would come back on..
I would think traction control from would make it better in the snow, it makes it SO much worse. I absolutely love the truck but this has to be the worse function I can find on the truck.. with the dbw tuning being second.
I also just order some tunes from 5 star, will they be able to turn it off? The form I filled out asked and I said to turn it off but it seemed to imply that not all trucks can have it turned off.
It has never done me any favors, just some grief a few times this winter. I took off from an intersection in 2wd, wheels just spun, too much ice, so I grabbed the tcase and pulled into 4x4..... nothing, somehow the traction control was keeping my truck from 4x4 operation. Basically, I looked like an idiot sitting at a green light just spinning the rear tires in my 4x4. I finally let off the gas long enough for the traction control light to go off, then the 4x4 worked. Luckily you're getting a tuner from 5star to keep it off. Post up when you get the tuner and how they turned it off.
I try to, but it always turns itself back on. Within minutes, it never stays off.. is that normal?
I have mine off and do so with the SCT Tuner from 5Star. Down here in the Florida sand it is a real pain as well. When I press the gas, if I want the wheels to spin, gosh dangit, they'd better spin!
When in a stock tune, even if I turned the TC off, when there was wheel slippage, the truck would activate the TC. That's normal.
sfgiants0660
6.7L Power Stroke Diesel
05-24-2022 03:29 PM
