1998 E350 Club Wagon XLT - Wet! Moldy! Sad!
I am going to assume that it is this part.
Sill plate- Interior Trim
9C2Z1142624AA
https://www.fordpartsgiant.com/parts/ford-plate_9c2z-1142624-aa.html?Make=Ford&Model=E350%2fE350+Super+Duty&Yea r=1998&Submodel=&Filter=(e=8-cyl-5-4l;t=4at-4r70w)
they also show it fitting here
FORD OEM 92-02 E-350 Econoline Club Wagon Interior-Rear-Sill Plate 9C2Z1142624AA
FORD OEM 92-02 E-350 Econoline Club Wagon Interior-Rear-Sill Plate 9C2Z1142624AA | eBay
9C2Z1142624AA
Anyone else familiar with electrical issues quite like mine? Still having the same issues with the speedometer/odometer and door locks. All other gauges on the cluster function normally.
I've noticed the box pictured below occasionally making a strange electronic relay clicking type sound when I'm inside the van. I can get it to recreate the sound when I move the plugs, but my other problems, namely the speedometer, persist when it's unplugged. Opened it up to look for damage and was unable to find any.
Replaced the old battery today and the found the reading out of the electrical harness at the vehicle speed sensor the same (1.37V).
Did a ground check at the same spot last night (out of the wiring harness at the vehicle speed sensor) with battery disconnected and ground at a bare metal spot on the chasis, and got a reading of about 2 Ohms, so I don't think it's a grounding issue.
I did check for resistance in cabin fuse panel at fuse 14 for the instrument cluster (battery D/Cd, no power in circuit), and found that though the fuse isn't blown, I got a reading of about 950 Ohms.
Still haven't taken the dash off since I haven't sourced a replacement for the steering wheel hub bolt, but I'm definitely starting to suspect something (possibly water damage?) behind the dash is causing the problem.
Anyone have any tests in mind that might help me narrow things down a little?
For anyone else troubleshooting vehicle speed sensor circuits, I found some great detailed information on Ford VSS units here:
http://www.atraonline.com/gears/2004.../2004_1_50.pdf
http://www.atraonline.com/gears/2004.../2004_3_34.pdf
Includes PCM, GEM, and PSOM pin numbers, some schematics, and diagnostic suggestions specific to multiple models manufactured 1989 to 2004.
Hope to get to some more troubleshooting tomorrow.
Do you have a 2004? Thread title says 1998.
I doubt the pin out is the same but it could be if the van parts are the same part number..
I have the 2004 EVTM manual and could look it up
More than likely the seal around the large picture windows on both sides has failed. It's not really a gasket, more of a rope sealant, unbelievably sticky. I passed on buying a '98 Chateau years back because it was a waterfall inside during a thunderstorm. Now my '95, stored indoors most of it's life, now has a similar condition. Big job, careful with the nuts and brackets holding the glass.
Good write-up here, not sure if I'm pulling the windows, or trying the flow-able sealant trick.
https://www.ford-trucks.com/forums/1...f-the-van.html
EagleFreek
32
08-18-2019 06:05 AM
GreeVan
24
09-03-2015 02:51 PM
Desert-Rat
08-25-2004 11:20 PM
