Transmission Cooler Lines FSA
I logged into the Ford owners site and noticed I had a Field Service Action on my truck to repair the transmission cooler lines. Is this the same as a recall? Has anyone else got this for their truck? Is it for the issue some of you have had on this forum? I googled it but couldn't find anything about it.
BTW, here is the info that popped up.
FSA Title: TRANSMISSION FLUID COOLER TUBES REPAIR
Field Service Action Number: 17B03
This, may ne was dry and it was just a quick bolt and washer replacement. If it is wet they replace the lines
I just got the same info. If there is no leak, easy fix, and they can order that part in advance. If there is a leak, longer fix, and they can't order that part until after they confirm a visual inspection. I asked the dealer to order the first part in advance so they can be prepared to fix it at the time of my upcoming service (assuming no leak).
Is this related to the problem some people were having with oil getting slung up above the driveshaft?
The truck I'm looking at was built 9/22 so it's probably in the FSA range. I wonder if the dealer has made the fix or if they will just wait for the owner to find the problem out.
My transmission cooler line ruptured and blew fluid all over my exhaust and the white smoke went flying. Gary Smith Ford here in Fort Walton Beach, Fl fixed it after it sitting on their lot for a week. I got in my truck and started it and put it in drive and a I heard a loud clicking noise coming from my dash. Come to find out the new lines were rubbing against the motor. I gave it back and the fix was and I kid you not... they plastic zip tied the lines to the top of the oil filter assembly!! I am trying to find the proper repair manual or service letter showing how Ford is ordering the dealerships to fix these lines so I can take it back and get it fixed correctly before the plastic breaks from the vibration.
