Old Betsy is Alive and Running! (with video)
Old 03-11-2017, 03:48 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
Originally Posted by bjmayberry2
Abe, Was there oil to the rockers? doesn't take much but if it's not there
BJ, I started my truck today. It popped right off! But as you know if you read my thread about One Step Forward and Two Back, I have another problem.
But to answer your question about oil to the rockers I was able to check that before I saw water leaking out at the thermostat housing. There is oil at the rockers. It is dripping out onto the little oil plates and also oil coming out of the overflow tubes.
Another question: on the one head the oil from the overflow tube is not hitting the hole totally. Not all the oil is going down the hole. Should I be concerned about this? Should I try to reposition the tube so it hits the hole better? Or should I leave it be?
thanks!
Old 03-11-2017, 04:01 PM
raerjim's Avatar
raerjim
raerjim is offline
Congrats Abe!
Old 03-11-2017, 04:38 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
thanks!
If any oil is getting down the hole you should be good. You could try to bend it to hit the hole better but you may want to leave well enough alone.
Old 03-11-2017, 07:47 PM
abe's Avatar
abe
abe is online now
With my luck lately I'd better not try it. LOL!
Yes there is some oil going down the hole, but some was missing and gathering at the bottom of the head. But with the valve cover on it should not be a problem, right?
Old 03-11-2017, 09:00 PM
df85732's Avatar
df85732
df85732 is offline
Abe, I'm sure you have seen the following Web page from John Mummerts Y block Web site. But just in case you haven't here it is. I addresses the head bolts. Click the blue Y below.
Y
Old 03-12-2017, 09:45 AM
Jim and Austin's Avatar
Jim and Austin
Jim and Austin is offline
Good job Abe, bet you are feeling pretty good about it!
Old 03-12-2017, 01:13 PM
abe's Avatar
abe
abe is online now
Thanks, Jim, but you have to read about troubles with the right head in my thread "one step forward, two steps back".
diesel_dan
01-20-2018 07:30 PM
Waltersboys
10-11-2010 04:54 PM
Julies Cool F1
15
03-01-2010 06:50 AM
Vijay
General Automotive Discussion
03-16-2009 04:13 PM
propaneman
10-31-2007 11:11 PM
Quick Reply: Old Betsy is Alive and Running! (with video)
