New 1954 F100 Build - Page 7 - Ford Truck Enthusiasts Forums
New 1954 F100 Build
Old 04-10-2018, 06:32 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
bjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant future
Jake I’m going to install a sliding back glass in my 56. What seal is correct? I thought you just used a standard rear back glass seal.
  #92
Old 04-10-2018, 08:46 PM
abe's Avatar
abe
abe is offline
abe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant future
Looks good Jake! It won't be long now.
BJ, I thought of doing that to my 54 back in 98\99. But I decided against it. I thought it would help with airflow on hot days. Ask MidFifty what they would use.
  #93
Old 04-11-2018, 03:49 PM
jakevidrine's Avatar
jakevidrine
jakevidrine is offline
jakevidrine is gaining momentum as a positive member of FTE.jakevidrine is gaining momentum as a positive member of FTE.
Originally Posted by bjmayberry2 View Post
Jake Iím going to install a sliding back glass in my 56. What seal is correct? I thought you just used a standard rear back glass seal.
i tried the standard back glass seal from mid-fifty, I cut it trying to pull the rope around. Iím not sure if the seal was the wrong size or the rope wasnít lubricated enough but I ordered the slider rubber from midfifty. It should be in Friday along with my side window lift chanels.
  #94
Old 04-11-2018, 03:50 PM
jakevidrine
I managed to get the instrument cluster and steering column back in and completed the wiring for the exterior lights. I also got the rear fenders and tailgate back on.
The spots are because of the water droplets in the windshield
  #95
Old 04-15-2018, 10:18 PM
jakevidrine
I e finished wet sanding and polishing all of the bottom of the truck, bed sides, tailgate, cab and fenders. All I have left is the back wall, roof and hood...
My clutch started sticking, looks like a need to fabricate a stronger bracket to rectify the situation..
anyway, this is how she sits at the moment:
  #96
Old 04-16-2018, 06:46 AM
Greg Rogers's Avatar
Greg Rogers
Greg Rogers is offline
Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.Greg Rogers has a great reputation on FTE.
You sure have done a great job and all in that attached garage! Well done Sir!!
  #97
Old 04-16-2018, 07:39 AM
jakevidrine
thank you Greg, the two car garage has certainly made for its own set of challenges but things have come a long way. I should have it on the road in a few weeks, just need to get the side windows working properly and make some adjustments to my clutch.
Also, I went with a brake light pressure switch and I canít get it to stop leaking...
  #98
Old 04-16-2018, 10:22 AM
acl9865's Avatar
acl9865
acl9865 is offline
acl9865 is starting off with a positive reputation.
That is one hell of a paint job.
  #99
Old 04-16-2018, 10:29 AM
jakevidrine
thank you! The compliments mean a lot to me. This is my second paint job, both sprayed in a Home garage. This one came out pretty good, there are a few imperfections but Iím able to fix them with a little wet sanding and polishing.
jeff54f250
57
02-25-2018 12:47 PM
Daniels54
23
02-18-2018 02:53 PM
Brian995
18
05-17-2017 09:12 PM
Ranger1979
16
02-07-2017 11:03 AM
Ranger1979
28
07-03-2016 10:38 PM
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
