Anybody running the 38 gallon rear fuel tank?
It looks like I'm gonna be replacing the rear tank in my 97 F250. So I hopped on the internet and started shopping around for one. It appears the 38 gallon option is only available for the years up to 1990 if I remember correctly. Is it possible to make this one work, has anyone done it? Thanks again!
Here was my install thread on another site
F26E 38 Gallon Rear Fuel Tank Install - Diesel Forum - TheDieselStop.com
I did a 2006 f350 6.0 cab and chassis 44 gal (same as excursion) but did had to modify the frame cross braces and straps but zero modification to fuel lines or fuel level sender (I used the 06 fuel sender) still need to add a skid plate though, and also I can fit 49.5 gallons up to the filler neck.
Yes I did, its not to tough. You might have to move your tailpipe a little and your spare won't fit anymore. I think it was Richard in Tucson who mounted his spare but it sure did hang down!
I put one in and it wasn't too bad. I didn't pull my bed but did have to remove my hitch and then put it back on after the tank was in. I bought some threaded rod to mod my spare tire mounts to remount it but haven't done it yet. It will hang low but I believe it will still be above the axle. I don't do any serious off reloading so it will be fine for me. It's nice to have the capacity. It not nice on the wallet when you run it down to empty. I think I get almost 40 gallons in.
I also had a buddy help, extra set of hands helped a lot.
