Color code help
Old Mar 8, 2017 | 03:24 PM
GEMCPHERSON's Avatar
GEMCPHERSON
Color code help
We have recently purchased a 74 f250. On the tag it has two letters for the paint code. I've read other threads that state the first letter is the primary colors and the second is the accent color. However when I compare these two letters to the ford paint code chart it states the combination is not possible. The two letters are NM. I can find "M" with no trouble for 74, that is white. I can not find "N" for 74. And the first letter being the primary does not work with this truck. The second letter is the primary. Any help appreciated.
Thanks,
GREG
Old Mar 8, 2017 | 05:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Was your truck assembled, sold new in Canada?
If so: 1974: N = Bright Green Metallic / M is the same as US trucks.
Old Mar 8, 2017 | 05:18 PM
GEMCPHERSON
I don't believe so. I'll post a picture of my door tag. I believe it was built in flint and ordered by a dealership in the greater Lansing area. I have the original dealer warranty card.
Old Mar 8, 2017 | 05:19 PM
GEMCPHERSON
It does have bright green metallic paint around the upper rear part of the cab.
Old Mar 8, 2017 | 08:05 PM
lakequ's Avatar
lakequ
i think that color is called light medium pine and thats the letter n but dont hold me to it and m is white and it says that your truck was made in Michigan
Old Mar 8, 2017 | 08:08 PM
GEMCPHERSON
I get the separate colors, but in 74 were they available as a combination? And was that combination available in the states? And I thought the primary colors came first?
Old Mar 8, 2017 | 08:23 PM
lakequ's Avatar
lakequ
Yes white would be your primary color and light medium pine would have been your insert and the top of your cab https://s-media-cache-ak0.pinimg.com...fe024fd0ea.jpg just like that
Old Mar 8, 2017 | 08:26 PM
GEMCPHERSON
But according to the tag white is the second letter and pine is first. Is this theory of primary colors first incorrect?
Old Mar 8, 2017 | 09:07 PM
NumberDummy
There's no N color code listed for 1974 US cars or trucks/Bronco's/Econolines.
There is an N listed for Canadian cars and trucks for 1974, but your truck was assembled at the Michigan truck assembly plant and ordered from the Lansing MI Ford district sales office.
Old Mar 8, 2017 | 09:13 PM
Arbiter's Avatar
Arbiter
Maybe double check the tag against the frame vin?
Old Mar 8, 2017 | 09:32 PM
GEMCPHERSON
I too gleaned the information as to where it was built and ordered from but it still states clearly on the tag it was two tone and white was second, green first. I'll admit I do not know where the frame vin is located. I also haven't taken the time to find out on my own where that is...any help?
Old Mar 8, 2017 | 10:14 PM
meangreen92's Avatar
meangreen92
It's on the top of the passenger side rail, where you can see it from under the hood. There should be another stamping, on the passenger side rail, under the cab.
Old Mar 8, 2017 | 10:17 PM
GEMCPHERSON
Thank you. I'll check it out at first light.
Old Mar 9, 2017 | 07:02 AM
CelticOne's Avatar
CelticOne
Regular User
Not my pic, but I keep it handy.
Old Mar 9, 2017 | 07:16 AM
GEMCPHERSON
Ok, so my front end is much different than this photo. I have leaf Springs, not coils. I've looked in the space marked in this picture but I have found nothing. Could it be somewhere else or possibly my frame is not a 74?
