4r100 Lost All Gears
Just posting this in case it's helpful for someone searching in the future, And trying to figure out what would have caused this.
Received a call from one of my employees this morning saying they lost all gears in the trans, My first thought was something transfer case related since I had just rebuilt (And upgraded) the transmission a year ago. After verifying that it was not the transfer case the pan was dropped to make sure the filter Hadn't just dropped out. All was fine there, Fluid looked and smelled good and no metal savings in the pan. Checked the feed bolts and those were tight. So remove the trans it is.
Below is what I found. Any ideas what would cause this? Or just a random mechanical failure? Also, just replace the pump gear and reassemble or should I be checking for other things while it is apart?
__________________________________________________ ______________________
My main question would be where the missing gear/pump parts are. Did something else fail to cause the pump to fail?
And my question is also, is there anything that could have caused this or just a random happening?
emerk86idi
01-01-2016 03:06 PM
MONAVIERONJON
02-25-2015 10:04 AM
eatfish
06-20-2007 05:28 PM
