2000 Ex v-10 Front End, Next Steps
Old 03-03-2017, 09:53 AM
Tadsen23's Avatar
Tadsen23
Tadsen23 is offline
I know there are threads out there but I figured I would ask anew....steering and suspension needed work. I replaced the upper and lower ball joints with some Moogs, Moog stabilizer bar links and a Monroe Steering Damper. I am extremely happy with the results, as it was pretty bad, but still want it better, newer, etc. Looking for suggestions for next parts to replace for both steering and suspension.........Its a daily driver with minimal heavy hauling. I have a 9500# boat that I tow a few times a year.
Old 03-03-2017, 11:08 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Tadsen, check out the tech folder for additional ideas. See the heading:
Suspension, Steering, Brakes, Wheels, Tires, Axles, Hubs, Transmission/Driveline
Lotsa options for you to browse.
Old 03-03-2017, 12:12 PM
Tadsen23's Avatar
Tadsen23
Tadsen23 is offline
That's where it is! I knew I had seen them before. Thank you.
Old 03-03-2017, 12:13 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Nothing wrong with that as products will improve over time, and sometimes products from reputable company's no longer are trustworthy, so getting the latest info is good.
But like Sean directed, check out the tech folder along with your inquiry because there really is some excellent info there, like changing the caster degree for better handling and less feeling of Excursion Wander.
...it was pretty bad, but still want it better
Better how?
Better components or better handling characteristics?
Stewart
Old 03-03-2017, 12:24 PM
Tadsen23's Avatar
Tadsen23
Tadsen23 is offline
I am looking for the basic less wander. I could live with it as is now, but I know it can be better based on forum info.
Old 03-03-2017, 01:37 PM
Stewart_H's Avatar
Stewart_H
Check out the first link in the Suspension section of the tech folder. The steering wander/5* of caster thread.
Stewart
Old 03-03-2017, 02:11 PM
afmedic's Avatar
afmedic
afmedic is offline
I had a ton of wander in the steering, turned out to be a busted tie rod end at the pitman arm. Wander is all gone now!
Philisophe
2017+ Super Duty
10-30-2018 10:59 PM
ProMotive
04-14-2014 09:18 PM
Mdub
1999 to 2016 Super Duty
18
11-10-2008 04:25 PM
sddesigns
08-19-2008 06:37 PM
buckshot047
07-10-2006 09:27 AM
Quick Reply: 2000 Ex v-10 Front End, Next Steps
