P/N ? Fuel Pump Pulse Damper, 85' 5.0L, Single Tank
Old 03-01-2017, 08:06 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
1985 F-150 Lariat, 5.0L, EFI, Standard CAB, Single Tank, 2WD
Any body have any Part Number information on a Fuel Pump Pulse Damper?
In-line, just before the Fuel Regulator in the rubber Fuel Line coming from the HP Fuel Pump.
Or is it a filter? Will pull it out this weekend.
Thanks.
Old 03-01-2017, 10:01 PM
ctubutis's Avatar
ctubutis
ctubutis is online now
Vinny - is the part listed in the pdf document?
File Type: pdf
Old 03-02-2017, 01:12 AM
vjsimone's Avatar
vjsimone
vjsimone is offline
Chris, it is not on the document. I was looking at this one and the two of the rest of the fuel system at the dealership a few days ago with no joy.
I'm going to pull it off in a few days, maybe there will be some numbers on it. It looks to be 32 years old. Thanks.
Old 03-02-2017, 10:07 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Is it shown in this illustration? 1985 F-Series 302 w/EFI - ???Gary's Garagemahal If so, give me the # and I can get the part #.
Old 03-02-2017, 11:20 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
My old 86 SVO mustang had one in the line up near the fuel rail on the engine, and it sort of looked like this one.
Standard FPD1 Fuel Injection Pressure Damper fit Ford Thunderbird 89-89 L6 3.8L
Old 03-02-2017, 11:33 AM
vjsimone's Avatar
vjsimone
vjsimone is offline
Gary, this object does not show up in any of the drawings. However, it is in-line installed in the middle of the Hose # 9J323.
My understanding is that the 85' F150, 5.0L EFI was an option, that first year of available F150 EFI, and made standard in 86'. So maybe it was an afterthought. If it is a Pulse Damper it would not be a carryover from 84' F150, but maybe from the 83/84 automobile EFI systems. Thanks.
Old 03-02-2017, 11:38 AM
vjsimone's Avatar
vjsimone
vjsimone is offline
That is a great find if you could not find one cheaper, and needed to replace one. That one is a different shape than my cylindrical one is, but would provide the same function and would fit in place of mine. I put it on my wish list. Thanks
Old 03-02-2017, 12:15 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I wonder if it is E57A 9155-HA? I Googled that number and the first hit reminded me that I'd run into something similar on Ray's truck a few years ago and it was discussed in this thread.
Here is what is said about it in the catalog:
Old 03-02-2017, 01:07 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
My understanding is that the '85 F150, 5.0L EFI was an option, that first year of available F150 EFI, and made standard in 86'. So maybe it was an afterthought.
If it is a Pulse Damper it would not be a carryover from '84'F150, but maybe from the 83/84 automobile EFI systems. Thanks.
There's no 9J323 on a car.
Pic: Here's what the truck parts catalog says inre to E5TZ-9J323-A
If one doesn't have the exact same description that FoMoCo calls a specific part, lotsa luck finding it in the text.
I looked for damper: nothing, looked for pulse, found a pulse air valve for the T/E system...and that's it.
Old 03-02-2017, 02:18 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Edited;
That makes sense. So it is may be a secondary fuel filter on the fuel line coming from the primary fuel filter connection according to Gary's post. Then there is another fuel line from the secondary fuel filter to the fuel rail/regulator connection.
My primary fuel filter in in the reservoir mounted on the frame. (9K044)
But, Bill's post shows a fuel line 9J323 from the HP pump to the fuel rail, nothing in-between.
Old 03-02-2017, 02:22 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
So what/where is the 9H323 CAP (Fuel pressure relief valve)? Sounds like a Damper to me.
Edit; correction, Not a Damper, a real Cap for a 9H321 Schrader Valve.
Old 03-02-2017, 02:50 PM
NumberDummy
EOVY-9H323-A .. Fuel Pressure Relief Valve Cap (Motorcraft CM-3462) / Available from Ford.
All 1983/89 Passenger Cars & 1985/89 F150/350/Bronco/Econoline with CFI or EFI
Old 03-02-2017, 02:55 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
First, I found that I had a page missing on my web site for the 302/5.0L's EFI illustrations - the page with the stuff up on the engine. I've added it: 1985 F-Series 302 w/EFI - ???Gary's Garagemahal.
Second, the illustration for the 5.0 does appear to show 9H323. However, it does show it for the 460, as shown below. It is just a cap for the fuel pressure relief valve 9H321. I can't find either of those on the 5.0's drawing, although the catalog says all with CFI or EFI used both of them.
Old 03-02-2017, 03:00 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
I believe this is the protective cap for the Schrader Valve that does not exist on the 85'.
Old 03-02-2017, 03:04 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Which means the Text part of the catalog is wrong since it says "All", and the Illustration part is right since it doesn't show it for the 5.0L.
Quick Reply: P/N ? Fuel Pump Pulse Damper, 85' 5.0L, Single Tank
