Paging SkySkiJason (page acknowledged)
Please send me an email to Sous04S4@yahoo.com I am looking for a good ZF6 mechanic in our neck of the woods.
Thread reference is below...
https://www.ford-trucks.com/forums/1...e-as-well.html
I just read through that fast, but my most likely suspect is failed pilot bearing and cheap clutch parts.
The factory-style pilot bearing is a really poor design and I've seen total failures in under 10k miles. Especially if input shaft was damaged due to previously failed pilot bearing.
I only use Southbend clutches. Not sure why 'reputable mechanic' wouldn't like their parts. ... But, their Kevlar pilot bushing is not a good bandaid - especially if input shaft is damaged. I have a friend mill pilot bushings out of oil impregnated bronze and we cut them the full depth of the flywheel for MAX support. I've put a couple of these in trucks with damaged input shafts instead of rebuilding trans (shifted good, etc).
If we pull trans and find a FUBAR input shaft, you're looking at trans rebuild ($2100 with shipping - I've been using All Star Standard Transmission in Tampa, FL).
Southbend recommends Con OFE clutch (one side is ceramic and other side is semi-metallic) for our application - up to 450hp tow rig. Mine lasted 125k miles at almost 400hp towing a full 50% of the time and BEATING it hard for dozens of passes at the drag strip and pulling the sled several times. Even though the friction material was all but gone, TO bearing failed
Please call or text me at (REMOVED PHONE NUMBER) and we can talk for a moment about where your shop is and when I can bring it in next week. I will go pick up the truck from the shop it is in now in the morning as I already feel better about it being under your control. We are willing to do whatever it takes to get this right, even if you think it requires a new transmission. (hope not, but it is what it is)
If you prefer to email your details, or the shops details, feel free to email something to Sous04S4@yahoo.com
Thanks again, I hope to hear from you soon.
UPDATE: Jason and I have been in touch. Bringing the truck back home first thing in the morning and talking to Jason about when to work my truck into his busy schedule.
Reps sent to Jason and we are looking forward to meeting up with him in the near future.
There is no other place on the internet like the FTE.
jason832
05-28-2019 04:56 AM
Eallend7
12-02-2012 04:53 PM
Scummer52
09-23-2011 06:47 PM
