1966 F250 Camper Special - One Owner - New to me
Your trucks steering wheel should turn easily so long as you're at least barely moving ...if not then you'll want to check the king pins and steering links.
As long as your brakes are operating as designed and adjusted (since they're not self adjusting ) you may not want to modify them. I drive my '65 F250 around 5,000 miles each year ...mostly interstate and often loaded or towing. They need a little more foot pressure but they stop evenly and aggressively. They do get squirrelly over 85mph :-). And remember if you put on new shoes, they will need to wear in a smidge before they will be at their best.
Your 1965 F250 has 12 1/8" x 2" front/rear brakes.
I took some better pictures of the interior. My truck does not have the emergency flasher in the panel. Is that correct or has it been removed? Pics include the original rubber floor mat with red flecks made in it. The rubber is now hard and cracked in a few places. No rust in the truck bed. Headliner still in tact. I put the arm rests on it. The seat has had the center upholstery replaced but final on the top and bottom is original. Lastly no cracks in the dash.
Yeah, just keep rubbin' it in.
Thanks for the valve cover gasket recommendation. I will be sure to get this type.
Very nice interior. When I took my truck out for the first time, I noticed the vents at the kick panels. I opened both of them and took off. Immediately the cab filled with leaves, to the point that it was difficult to see and breathe. It took me a good hour to clean up the cab and the vents, which still had a substantial amount of leaves after flooding the cab.
Hi Tripleframe, Thanks for the info and the picture of the original hub caps. I put new tires on my truck today and yes mine is the one piece wheel. The spare tire still has the original split rim. I am going to find a new rim and make them all the same. I found a set of hub caps off a 1972 model which are closer but still not 100% correct.
While it was on the rack today I ask the mechanic if I needed the king pins rebuilt. There was about an 1/8 inch of play on the drivers side and none on the passengers side. The rubber bushings are shot so those need to be replaced. He said the rivots had to be ground off and bolts put back to replace the rubber bushings. He is going to give me quote Monday an I will decide if I do it myself or let him. Here are more pics; Hub caps, bushings, spare tire, side tool box that I need a lock for if anybody has one.
I've replaced the radius arm bushings in your photo on my '65 F250 and a '94 F150. You do NOT need to grind off those rivets. Set the truck frame on sturdy blocks and lower the I-beams enough to pull them forward out of the brackets. Might as well do both king pins, repack front wheel bearings, and replace both I-beam bushings at the same time.
#30
