Very high/rough idle issue
Hey guys, I'm working on a customer's E550 that is idling very high and running rough. It's idling at 1400 rpms and I have codes for the ICP (P1211, I just replaced that sensor) IAH (P0541) and have cylinder contribution codes for cylinders 3 and 6. I'm about out of ideas, I checked the UVCH. I also just replaced the glowplugs, it ran fine right after doing the glowplugs then started doing this. Thanks for any help!
I ended up using an aftermarket sensor against my judgement because she gave me a $300 parts budget to fix any oil leaks, change glowplugs, and icp sensor... I ended up going over that by quite a bit obviously as it was so she didn't want to spend the extra on the motorcraft sensor. I'll have to have them check the oil in the tailpipe, I don't really have easy access to the truck because it's about 20 miles away from me and I'm doing it as an extra side job as a favor so I'm not able to get to it a whole lot between working full time and school.
spease209
10-09-2009 12:04 AM
modracr62
11-21-2007 09:56 AM
