2001 f350 trans problems
O. Did not know that. Something to think about..What if one of the other tranny's fail. Any warranty on that one? Also, if you are saying that you will rebuild yourself, you have to pull the tranny out anyway right? So take the transmission out and drive it to the shop that is going to honor the warranty. Sure it will be inconvenient, but may be your best avenue.
It sounds like you have come up with a plan to get your truck back on the road quickly with a used trans and are planning to either have the original rebuilt or do it yourself, that's great! I'm glad that this is going to work out for you without having your work truck being down for an extended period of time.
Welcome to the forum, as you can see from the responses here, there are plenty of good folks, some with enormous amounts of subject matter expertise ready and willing to give excellent advice to help you out. You may also notice that all of their responses are easier to read and understand exactly what they are trying to say because of punctuation. No one is suggesting, even remotely, that this an English class, but some small amount of punctuation can go a long way in keeping the readers interested enough to offer up advice. This IS a truck forum, but it IS also a written word form of communication, so making your written words easier understand by clearly separating your thoughts and ideas makes those thoughts and ideas more clear to the readers. And isn't that the goal, having the members understand clearly what you are asking when you are seeking help?
Thank you!
So it's probably best not to re use that one ?
Not unless you cut it open and clean it. Transmission shops do this all the time.
There are no other transmissions that will bolt in and work. If you were to change to any other transmissions you'll have a huge amount of work and cost to get a computer to make it shift.
