Who's using Dodge 20" steel wheels and pics
Well I finally got my 4th Dodge spare 20" steel spare wheel. I would like to see pics of your truck with these and what your suspension set up is.
I have the DJM drop beams but have not installed yet. Not sure what I will be doing to the rear so looking for ideas.
Justiz I wanted to check out your truck again but dang Photobucket.
Thanks
Kenny
68 F100 shortbed.
Thanks
Kenny
68 F100 shortbed.
I went to the second page of Hio's Compilation sticky at the top of our page.
Read First: Technical Info Hyperlink Compilation ( 1 2)
HIO Silver
and grabbed this list for you to look through.
Lowering, IFS, IRS & Suspension Related
Flyboy2610's DIY: Replacing King Pins & Bushings (LOTS of pics!)
Fatman Fabrications MII IFS Installation
Fatman Fabrications Bolt-on Axle Flip
DJM Suspension - Lowering I-beams & Components
FTE: AIM/DJM Lowering Thread
Bilstein Shocks & PN Info for Dentsides
FTE Thread: Chocko's 79 LWB F100
Airbagit.com Axle Flip Kit
Paul Horton's Welder Series - DIY Mustang II IFS Components
Mustang II IFS Kits
Jaguar XJ6 IFS Swap into an F-100
Team 321's 89-97 Cougar/T-bird'Lincoln MN-12 Independent Rear Suspension Kit
Team 321's 89-97 Cougar/T-bird/Lincoln IRS Installation Article
Classic Trucks Magazine Thread: MN-12 IRS Retrofit
Fordification Thread: Spring Hanger Flip Pics
Fordification: Spring Hanger Flip - Pictorial
Fordification Thread: Spring Hanger Flip Shimming
Fordification Bumpside Thread: Details on Long Bed Pinion Angles After Full Spring Hanger Flip
FTE DIY Fabrication! Axle Flip Saddles and Shock Bracket Extensions Drawings with Dimensions
Bolt Circle/Pattern Guide & Cross-Reference Database
HIO Silver
Mustang II IFS Kits
.. Typically the options are: DJM shackles and spring hangers; flipped spring hangers; then an axle flip & frame C-notch.
In terms of Dodge 20s, there was a thread within the last six months if I recall correctly, I suggest using the advanced search (never the basic 'search') for this forum and I am confident threads will pop up.
Here was mine. DJM beams in front with replacement moog coils and a djm flip kit in the rear. 1" spacer on passenger side.
https://www.ford-trucks.com/forums/8...l#post11494949
With a 2" spacer on the passenger side later swapped for a 1". 1" spacer on the stock spare tire carrier for the 20.
here is my old truck with them. DJM beams up front. Axle flip out back.
285/50/20 tire back
245/45/20 tire up front
Attachment 205672
285/50/20 tire back
Attachment 205672
I'm finally getting read to install my Dodge steelies but trying to figure out what size tires I should run. I will be installing my 4.10 this weekend too.
Fun times
Kenny
Hotrodkid
01-24-2013 05:39 PM
