85-91 RSK with Super Duty springs - Ford Truck Enthusiasts Forums
Old 02-26-2017, 11:08 PM
Vadis's Avatar
Vadis
Vadis is offline
Vadis is starting off with a positive reputation.
With tax return season coming up I was looking into getting an RSK fabbed locally as shipping would be killer from either PMF or Sky.
I noticed nether company has any info on a RSK on the older frames with SD springs.
The SD springs are 3" longer then the stock springs if I'm not mistaken. That obviously moves the mounting point forward from the shackle position by that much. What I need to know is the 2.25" the PMF kit talks about is 2.25" lower then the shackle bolting point for the leaf?
Old 02-27-2017, 06:40 AM
IDIoit's Avatar
IDIoit
IDIoit is offline
IDIoit is gaining momentum as a positive member of FTE.IDIoit is gaining momentum as a positive member of FTE.
are you attempting this with a TTB?
Old 02-27-2017, 08:50 AM
Vadis's Avatar
Vadis
Vadis is offline
No, it's being done on my grandpa's truck which was a TTB 44 but I've already swapped it to a '94 Dana 60 with F-350 springs.
Old 02-27-2017, 09:09 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
Sky actually does make a RSK for the 80-91 trucks
Old 02-27-2017, 09:16 AM
Vadis's Avatar
Vadis
Vadis is offline
I noticed that but they say OBS springs in their write up and not Super Duty.
Old 02-27-2017, 09:25 AM
IDIoit's Avatar
IDIoit
IDIoit is offline
I built my reverse shackle kit spent 60 bucks,
and about 15 hours
DIY RSK. no need for expensive kits | Diesel Truck Forum - Oilburners.net
Old 02-27-2017, 10:39 AM
Diesel_Brad
Crap. Totally missed that. Sorry
Old 02-27-2017, 12:12 PM
Vadis's Avatar
Vadis
Vadis is offline
I built my reverse shackle kit spent 60 bucks, and about 15 hours DIY RSK. no need for expensive kits | Diesel Truck Forum - Oilburners.net
Looks beefy. Maybe a little more then I would need. I'm also going to need the space that huge square tubing takes up. I'm thinking basing the design more on the kits you could buy but obviously modified for the older frame ends and SD springs. Thanks though, good write up.
No problem. I was actually reading the write up you did in 1 of the forums were you used a Sky kit awhile ago. Pulled a lot of info from that.
So if I were to attempt this myself I would only have to worry about boxing the frame in. Making sure the front bolting location is both 3" forward of the shackle and 2.25" lower then the shackle at a 90 degrees angle?
I will most likely just order rear shackles from Sky as they're only $100 and shipping wouldn't be nearly as expensive as an RSK bracket.
Old 02-27-2017, 04:39 PM
ifrythings's Avatar
ifrythings
ifrythings is online now
ifrythings is gaining momentum as a positive member of FTE.
I noticed on the superduty trucks they have the shackle in the frame with a bolt in bushing, I know a lot of people don't like the idea of drilling a 1-2" hole in their frame but this would get rid of the 2.5" lift and use junkyard cheap parts. Just wondering on the general thought of this?
Also do you need to have another crossmember/re-enforcement in the front?
Old 02-27-2017, 04:53 PM
Diesel_Brad
not that simple. it would wreak havoc on the caster if you did that
Old 11-02-2017, 11:12 PM
Vadis's Avatar
Vadis
Vadis is offline
Figured I’d just bump this to talk this through and get some thoughts. I’m going to attempt to build my RSK after all. I’m going to base the upper part that attach to the frame on the 85-91 Sky kit:
But base the bottom on the PMF kit to clear a 92-96 bumper and have minimal lift. I plan to weld on the 92-96 bumper mounts at the ends of my frame.
I found a thread on here with some pictures of a 2.25 PMF measured up and am having trouble understanding somethings. If I measure from my shackle bolt on the frame to the leaf bolt I get 4 7/8” if I add the 2.25 from the RSK it would be 7 1/8” but looking at this picture and using the slotted hole in the frame, which is the same spot on my frame but higher up then the shackle it looks like 6 3/4-7”.
Can someone confirm that measurement from the slotted hole to the leaf spring bolt?
Diesel_Brad
07-15-2018 07:05 PM
Diesel_Brad
02-04-2018 08:16 AM
MEvans043
05-13-2016 10:20 AM
slandry
04-21-2016 09:45 PM
800screws
16
02-20-2016 11:44 AM
Quick Reply: 85-91 RSK with Super Duty springs
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
