2002 F-350 Super Duty knitted vinyl upholstery
Hello, I'm looking for suggestions on where to find an OEM type seat cover for a 2002 F-350 with a gray knitted vinyl full bench. The OEM part is discontinued, and I can't find any other OEM type seat covers available other than full vinyl. I only need the bottom seat cushion portion. Suggestions appreciated. I have searched both on the forum and online extensively, and talked to a few upholstery places but the material seems to be the problem.
Tim
Tim
I have the same style bench in my truck but it is from a standard cab so it has an extra lever. I am going to try replacing the bottom cover with one from a rear bench. I replaced my rear seat with a newer one so the boys have headrest.
I have not looked into if the part numbers are the same or not, but it may be an option.
Seat covers should be fairly easy to find, I just did a google search and came up with a bunch of them. I clicked on the precisionfit.com link and it looks like they have what you're looking for.
https://www.google.com/#q=OEM+style+...+seat+covers&*
http://www.precisionfit.com/catalog/...Fdm6wAodHbMKhg
If these don't work, then look up a local upholstery shop and get a quote from them, I'm figuring probably around $500 for a local shop to recover your seat.
john jamieson
19
06-24-2020 09:58 AM
