1948 ford f1 "REAR FENDER" front patch
OK..been along day as I try to research parts that I need to move my project forward..ordered the cab floor pan, the rear cab patch corners, front fender lower rear patch panels etc..but why can't I find the "REAR FENDER" front running board side patch panel??
Some help please..rather be working than researching parts..lol
Sounds like a good excuse to, as Nick suggests, learn how to use a shrinker/stretcher. Some quick videos here Shrinker/Stretcher Combo Set-Two BodiesTwo Jaws.
For this job you will need a mig welder or somebody that has one.
F-1 slow down on this it will take a few years to do a good job on this truck
Read more threads study welding or glueing which ever you choose but patches on the fenders are going to need to be welded I believe lap joints won't work learning were you can't see after is the way I learned to weld not that I can weld even a little. Making patches for under the floor who is going to get under the truck to see it. Harbor freight is where I got some of my tools east wood is where I got my shrinker/stretcher others got a welder from them so check around this is going to cost$$$$$ here is a pic I blab to much
Rot
Patch
I copied others on FTE
Rot
Patch
A tool that helps with lap joints is an air punch/flanger that I got at Harbor Freight. Air Punch Flange Tool
You can flange an edge after you cut out the shape so it fits flush. The hole punch makes fast and clean work of punching holes for plug spot welds or rivets.
I checked the thickness with my sheet metal thickness gauge. My original cab is 18 gauge and the new cab corner is 18 gauge. I actually cut my old cab corner off lastnight and test fit the new. It fits darn near perfect. Just a little tweaking on the door lip side. It even impressed my hard to impress dad.lol
Rokcrln
24
02-15-2014 03:03 PM
mike01082
07-19-2010 05:46 PM
dick1950
03-15-2008 10:21 PM
sancochojoe
03-09-2005 09:08 AM
