Small Vac Leak
Small Vac Leak
The check engine light came on and when I hooked up the scanner it gave me the code for a small vaccum leak. I can't remember the code # right now I'm at work, but I do know that it was for the vaccum leak. Does anyone have any idea's where to start looking for this leak? The truck doesn't seem to sound or drive any different. By the way it is an 02 f150 4x4 with the 5.4L.
Thanks
Thanks
Alright finally got the code P0442 EVAP emission control system leak (Small).
I could be completely off base but I was told this was a small vac leak. Can anyone tell me what would cause this? If ya can could you be so kind as to tell me where this is and what the H#$% it would look like. Thanks for all the help and Merry Christmas
That can be like looking for a needle in a haystack.
P0442 - EVAP Control System Leak Detected (Small Leak)
The PCM monitors the complete EVAP control system for presence of a small fuel vapor leak. The system failure occurs when a fuel vapor leak from an opening as small as 1.016 mm (0.04 inch) is detected by the EVAP running loss monitor test.
1)After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
2)Small holes or cuts in fuel vapor hoses/tubes
3)Canister vent solenoid stays partially open on closed command
4)Damaged, cross-threaded or loosely installed fuel filler cap
5)Loose fuel vapor hose/tube connections to EVAP system components
6)EVAP system component seals leaking (EVAP canister purge valve, fuel tank pressure sensor, canister vent solenoid, fuel vapor control valve tube assembly or fuel vapor vent valve assembly)
Item Part Number Description
1 9030 Fuel filler cap
2 9C052 Fuel tank pressure sensor
3 9B593 Fuel vapor vent valve
4 9C915 Evaporative emission canister purge valve
5 9F945 Canister vent solenoid
6 9D653 Evaporative emission canister
7 9002 Fuel tank
8 9C015 Fuel vapor control valve
9 9189 Fuel filler pipe check valve
Evap canisters & vent solenoid.
7 9002 Fuel tank
Originally Posted by 02f250fx4
So if the truck is still running fine is alright to drive till I get the time to find the leak? And also will this be enough of a leak that I can see fuel leaking, or is there an easier way to find this pain in the @$$ leak. Thanks for all the help you guys are a life saver.
mikeyc0120
1999 to 2016 Super Duty
06-24-2010 08:01 AM
