Are these NOS brake shoes worth saving?
I was getting some NOS parts today and came across these brake shoes. They were not in boxes and I couldn't see any engineering numbers on them. I don't know if they are for cars or trucks. But I'm quite sure they are Ford as all the other parts were from a Ford dealer.
Are they worth saving and selling? Thank you.
So what are they worth? I plan on selling these. Will a guy that needs some be able to recognize what he needs.?
I was curious about the bonding adhesive having age limitations, so I checked. Apparently there are none.
Browse Papers on Brake linings : Topic Results - SAE International
I think they might bring $65 per axle once cleaned up and identified, with the WYSIWYG caveat.
A very good point, but is that for aftermarket with no core charge? I haven't bought any drum brakes for a long time though. Relining and arcing the shoes, and turning the drums for the F-6 mixer was $220 per axle. Maybe too much?
Yes, brand new ones with no core charge are about $25 - $35 per axle set. You can get them at many stores including RockAuto. I have also seen old bonded shoes where the lining material pulled away from the metal shoe. I wouldn't trust old bonded shoes either.
One thing I always worry a little about is selling something steering or brake related that's used or in unknown condition. I am no lawyer but I think there could be some level of liability if a catostrophic failure occurred, and if there is not, would be an expensive process to find out, and not worth the couple bucks you might make on it. I probably just worry too much about stuff like that but always a thought in my mind.
If the linings are bonded, but have holes through the shoes for rivets, then rivets can be added. I have seen one set of shoes on a car de-bond.
As for application, they may fit a wide range of years. I recently discovered that the rear brake shoes for mid 70s Mavericks are interchangeable with 53 sedan rear shoes.
edit: looks like everyone beat me to posting this information.
