Severe rattle on acceleration
I have a 90 F150 with the 300 I6. Recently (last month), the truck rattles/shakes a lot when accelerating. It's severe too. It gets better at higher speeds (like 65+) but that may just be because it's about to shake apart. I initially thought it was an issue with the rear fuel tank but have ruled that out. The heat shield on the cat is rattling something fierce too but don't think that's related. Clutch is new as of Nov 2015 so doubt it's that. Could it be exhaust related? Doesn't feel like anything front end either because it steers and handles fine. Suggestions?? I'm not wanting to throw money at it to diagnose. I bought it for $1500 and have put $900 into it so I'm close to the buy a new one threshold. It has 144k original miles too.
No, replied to this post. Shaking/rattling could be a miss caused by bad spark plugs. Might as well verify fuel too.
...very true ... and while we are on the subject, arty ... might be a good idea to run your engine in the dark to see whether any sparks are escaping from their wires.
Just trying to point everyone in the right direction. In neutral/clutch disengaged, how's it rev? smooth, or rough?
Also, if there's vibrations at speed, it may be caused by losing a wheel weight. New tires should have been balanced, and you may have lost a weight since then, due to faulty installation of said weight, or from other reasons ()
Andy Hawks
02-27-2019 12:55 PM
comtb
12-27-2014 03:45 AM
