How to fix play in shifter arms?
Old 02-24-2017, 11:07 PM
91Fbody's Avatar
91Fbody
91Fbody is offline
I believe this is like what I have(3 spd hd). If I reach up there and grab them, there is slight play in both. Not enough to be too concerned with but I'm trying to tighten my shifting up. If it's too involved, I'll let it ride.
Old 02-24-2017, 11:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
I think some play is par for the course. The mechanism that holds them in position inside the shifter cover is like below. Not sure what would really wear. There is a spring between two ***** that could be weak.
Old 02-24-2017, 11:16 PM
91Fbody's Avatar
91Fbody
91Fbody is offline
Well, that looks interesting! I'm guessing the slop might be from the holes(bushings?) the arm shafts rotate in.
Looks like I'd have to grind the welds off, and go from there. Not too keen on doing that. I think fixing the other issues in the linkage and shift shaft should give me good enough improvements. Or at least I hope.
Thanks!
eberf
02-18-2017 06:38 PM
irhunter
WTB - Parts & other
07-27-2015 08:50 AM
ADOR
10-30-2013 07:02 PM
chriscris
09-01-2012 06:27 AM
masseysbronco
07-27-2010 07:25 AM
Quick Reply: How to fix play in shifter arms?
