89 F350 Fun Ton Plow Truck Turbo 460 FiTech
#229
Cylinder checks out good. Clipped 30 psi of regulated air on the cylinder and the engine turned over. Then pushed on each valve and got a pop out of the intake and an instant rattle out of the rain cap.
Wasn't expecting the rain cap rattle, I said what the???
Seems to be a sneeze at this point from bad wires.
#231
#232
#233
#237
"I got nine lives
Cat's eyes
Abusin' every one of them and running wild"
-back in black.
pretty pretty work.
some interesting starter relay and circuit breakers there on the fender wall.
this very day i am designing a system "far from ford" for my old 86 diesel.
care to tell me what you have there?
thx.
Cat's eyes
-back in black.
pretty pretty work.
thx.
#238
Ac and Dc lol! Fuel pump output on the FiTech activates the 120 amp continuous relay then to a 25 amp circuit breaker then to the fuel pump. Also just a stock solenoid for normal starter duty, and solenoid for plow.
No need for 120 amp but was the cheapest and can feed methanol pump and vacuum pump later with more circuit breakers if I add those.
FiTech can feed this fuel pump with it's output but wanted to keep the heat out of the throttle body/electronics. The output is rpm sensitive, so it will stop the fuel pump with rpm loss. If I go crazy later, will add an inertia switch for additional safety.
#239
