My 450 over the scales stickergate 2??? LOL
#31
#32
took me awhile to figure out why my front axle was lighter while towing but then I remembered I had full fuel with just the truck and half a tank this time
First trip out on the road. If it looks a little squatting to you I forgot to air my tires back up. Had them at 60 psi for the winter.
Puts the Cyclone at 19220 lbs and 3200 lbs on the pin. That's only 16.65% with full water and toys. Makes me wonder where I'll be for pin weight with just the toys in the back.
#33
Made it back to the scale. First tow on the highway with the new truck. It was only a 50 mile round trip but very impressive. I set the cruise at 60 on the way there and 65 on the flip side. I'll have to do a little more with this but I got better mpg at 65 than I did at 60 and I had a slight head wind at 65. 8.5 mpg at 60 and 10.5 at 65. There was a couple little hills and the truck held set point and never even down shifted. Trailer was heavier than expected but I wanted the heaviest potential tow I would pull. I filled the 100 gal fresh tank and had the Can-Am and Kawasaki Vulcan in the garage. Only things missing would be the 45 gallons of gas which is under the back and my two 30 pound lp tanks are empty in the front. I can't say enough good about the F450. Best purchase I've ever made.
#34
#35
If it is I have the same trailer
#36
Some folks I have asked, including our state police expert say you can't use a class c if your GVWR's added together are over 26k. My license says GVW - I'm going with that.
#37
Correct. MD has a non-commercial class A. My rig, fully loaded will be about 25,500 if I don't get an aux tank.
1987F250460
16
09-14-2011 12:54 AM
