Turn signal Stalk - Ford Truck Enthusiasts Forums
Turn signal Stalk
Old 02-22-2017, 11:42 AM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.
Turn signal Stalk
Is the turn signal stalk supposed to have a bend in it? Thought I would ask before I straighten it.
Thanks Brian
Old 02-22-2017, 12:30 PM
Coastal68's Avatar
Coastal68
Coastal68 is offline
Coastal68 is gaining momentum as a positive member of FTE.Coastal68 is gaining momentum as a positive member of FTE.
No.
Maybe the PO took a hard right.
Old 02-22-2017, 12:31 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
Right turn Clyde.....
No. Looks like the PO put a different steering wheel on it and bent that stalk to match.
Old 02-22-2017, 12:41 PM
Coastal68's Avatar
Coastal68
Good one!
Friend of mine had a cat that could only turn right. Don't know why. If he wanted to go left he had to make a three quarter right circle.
Old 02-22-2017, 12:55 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Originally Posted by Coastal68 View Post
Good one!
This guy has the same problem. You can look at him and tell.
Old 02-22-2017, 01:08 PM
Brian1971f100
Thanks for the clarification, maybe PO thought it was a tilt wheel. I will straighten it. The steering wheel is a ford wheel 2 spoke horn across the wheel.
Old 02-22-2017, 01:31 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
2 "straight across" spokes? If so that would be an early 70's CAR steering wheel.
Old 02-22-2017, 01:44 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Upper pic: Same as 1970/72 car.
Lower (upper) pic: Same as 1973/77 F100/350; 1974/77 Bronco; 1975/77 Econoline (except 1975/77 F100/350/Econoline with Speed Control).
Old 02-22-2017, 02:21 PM
Brian1971f100
Illustration #2 is the closest to what I have
Old 02-22-2017, 02:46 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Thanks Bill.
Then in 1978 Ford changed from the above style 2 spoke steering wheel to a "Gull Wing" 2 spoke. But my oct 1988 microfische says all 73/79 pickups and Econolines all took the same T/S stalk. Originally D0AZ13305A which was all chrome. Later this was replaced by D3TZ13305B. Which was a chrome stalk with a black ****.
Wish I had an older slide. I remember the 13305's differently. I could swear originally the D3TZ13305B was 1973 specific. And the rest D3TZ13305A. Then both D3TZ - A and D0AZ numbers being replaced by D3TZ13305B.
Old 02-22-2017, 02:52 PM
Brian1971f100
Mine is a chrome stalk with black ****.
Old 02-22-2017, 03:13 PM
Coastal68's Avatar
Coastal68
My 68 has the older style turn signal - a holdover from the 61-66 trucks, I think.
Old 02-22-2017, 03:37 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
"BLACK ****":
64/66 F,B,C,CT,H,HT,N,NT,T350/1100.
64/65 F100/250 4X4.
66 F250 4X4.
67 F800/1000,C,CT,N,NT,T500/1000
"CHROME HANDLE":
64/66 F100/250 4X2
67/69 Bumps and many other trucks.
"CHROME **** AND HANDLE".
70/early 72 Bumps.
No description but it's all chrome also from my memory.
Late 72 Bumps.
Old 02-22-2017, 03:40 PM
NumberDummy
C0KF-13305-AP .. T/S Handle-Painted w/black **** / Obsolete
1961/66 F100/1100.
Old 02-22-2017, 04:32 PM
Brian1971f100
Coastal I like you wheel. I will be getting a new steering wheel, I just haven't made up my mind on diameter and style yet.
Quick Reply: Turn signal Stalk
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
