'72 C700 How to bleed/add fluid to hydraulic clutch
hi, It would be great to get a tip on how to add hydraulic fluid to the clutch system. I see under dash what looks like the master cylinder. And I can see the slave cylinder at the transmission. I will be replacing the flex hose which is currently leaking slowly.
OK, post 18 and 33.
https://www.ford-trucks.com/forums/9...es-owners.html
More of the same via the links in post 5.
https://www.ford-trucks.com/forums/1...h-systems.html
Post 3 shows the master cylinders and the parts etc:
https://www.ford-trucks.com/forums/1...3-c-600-a.html
Take the old one off and take it to a place that specialize in hydraulic hoses. They can usually replicate anything.
1973/86 C/CT600/900.
No Ford dealer or obsolete parts vendor has any, none on ebay.
I would assume that the tube or the parts to make one up is available from auto parts stores, when you consider how many of these trucks are still in service.
ManfredVonRichtofen
1978 - 1996 Big Bronco
02-21-2012 11:53 PM
fordguy300
10-22-2008 07:13 AM
my91EXP
11-22-2003 11:54 AM
