Diesel still in oil, even with e-fuel. Am I going to die?
#301
#303
Hmm I'll see if I can try the blue monster thread tape if I can get it locally. This is what I'm using currently: https://www.amazon.com/Permatex-8063.../dp/B000HBNTGY
So you think the blue monster tape will seal better? If not, I'll go ahead and try JB weld before replacing the filter base.
Inspect the threads. If they look like they should, Blue Monster will seal it up.
#304
Ill go ahead and see if I can get some today and try it out. I think I read walmart should stock it.
#307
My local Ace Hardware had some of this tape so I just finished putting it on. My main outlet was leaking, but I noticed the two bungs in the rear of the filter housing were seeping as well. I don't know why this filter had all the leaking and the water seperator/filter didn't. Anyways, I just finished wrapping up all the outlets that were seeping so I'll see if it stopped! If not, I may try one more time with taking the filter housing off though so I can get better leverage on all the fittings. Then it's JB weld time if that doesn't work.
Oh I think the EBPV delete might make a difference in the running of the truck. I don't know if it will do a lot, but apparently the EBPV takes up like 1/4 of the diameter of the exhaust outlet even when open so it will probably help a little! Removing the sensor and piping from the front of the passenger side manifold probably doesn't do anything, but it's a cleaner look! I was able to remove the bracket on top of the HPOP reservoir as well that holds that sensor so there is less clutter in the way of things.
#308
#309
Opening the exhaust seems nice as well, but I wasn't planning on having it be a huge performance increase by any means. It is nicer not having the plunger thing and a smaller turbo pedestal in there. Plus with the exhaust ceramic coated, things seem a little cleaner and nicer in there!
As a sine note, I think I've been driving around with my coolant filter closed off. I had the nozzle perpendicular to the filter, so I just flipped it up. I can't remember which was is open and which way is closed but I'd assume the way I turned it is now open. The water pump is the one that ambulances have apparently, I purchased the coolant filter water pump kit that sold on dieselsite.
#311
So the good news is that it appears my tires will break loose instead of my axle/driveshaft going, but I'm still a little nervous of that happening.
So far, it appears that I may have fixed the fuel leak with the blue monster thread tape as well! It was a little wet on the fuel filter this morning when I drove off, but that may have just been residual fuel seeping down. It didn't appear to get any more wet and I didn't notice any drips after driving today. I'll keep an eye on it, but I may be leak free now!
#315
I'm pretty sure I'm going to try and get a 3:55 rear end, and then just do an 8 lug swap on the front axles. I know it'll still have the weaker front axle, but I don't really think it's going to be too much of an issue because I'll never really need tons of power on the front. When I do go off road, I can't see my putting too much stress on the front. I suppose only time will tell for that though!
Thank you! I've notice no more leaking so I think I actually have a fully leak free truck now! I can park over driveways without worry about leaking spots!
Now I have to move onto intercooling, axle swaps, and the scangauge interceptor addition. I'll probably get the scangauge first because it's the cheapest.
