6.2L V8 Discuss the 6.2L V8
2018 F150 King Ranch or Platinum 6.2 L
Old 02-27-2017, 11:22 PM
scozim's Avatar
scozim
scozim is offline
Originally Posted by Chuck's First Ford
a towing vehicle needs to be setup for towing..
a Gas towing vehical needs gears... and smallish wheels/tires.. 17,18s
3;73 or 4:30...
Gas engines needs to be able to spin..
if going over 18's .. then 4:56 or 4:88
Interesting and not something I'd thought about? Due to weight an rolling resistance? I'm looking at a 11 6.2l F150 Platinum right now with 20's and 3.73 limited slip. Max I'll be towing is around 6500 - and it seems like it should do it fine.
Old 02-27-2017, 11:27 PM
RainDesert's Avatar
RainDesert
RainDesert is offline
In the F150 I wouldn't worry so much. There's no doubt the 4.10's would be better, but finding a used Platty 6.2 F1 prolly isn't easy as it is. Get a good deal, you can always re-gear if you ever find the want.
Old 02-17-2018, 04:30 PM
Kycat23's Avatar
Kycat23
Kycat23 is offline
6.2 gmc
I hated gmc until I bought my wife a 6.2 v8 Denali Yukon. I was jealous lol. The 5.0 ford couldn’t touch that gmc 6.2 and the best ford motor I have ever had was the straight 6 in my 1985 f150 it has 300 thousand miles on it and the oil pump went out and I ended up with a 6.2 v8 gmc denali pickup. The economist just didn’t have it I drove them all thinking the dodge would be a contender. Not even close as well.
Old 02-18-2018, 09:55 AM
rvpuller's Avatar
rvpuller
rvpuller is online now
Why don't you look at a F250 with a 6.2 then you can get any trim level you want.
Denny
Old 02-20-2018, 09:23 PM
J Standard's Avatar
J Standard
J Standard is offline
A 3.73 5.0 runs hard, I bet it would walk your 6.2 empty. Loaded it might out pull it but overall the 5.0 is a great motor.
Hell with, buy a 6.2 Super With 4.30 gears and have the big motor and big truck.
Old 02-25-2018, 04:14 PM
Little General's Avatar
Little General
Little General is offline
I agree with Ron94150, my ecoboost with 3.73 gears pulls like a power stroke diesel. I pulled a full size caddy across nc and could not believe the pulling power it has. i came from diesels and a 6.2 F350. i am a firm believer in these little engines.
Old 02-25-2018, 04:58 PM
leadmic's Avatar
leadmic
leadmic is offline
The 2018 F150 ecoboost tow ratings are in 3/4 ton territory. In fact I wouldn't be surprised if it has a higher tow rating than a 2013 6.2L F150 and I bet it would probably out pull it.
Mark
640 CI Aluminum FORD
6.2L V8
05-29-2012 09:53 PM
Competition
07-20-2010 06:39 PM
2009 - 2014 F150
13
06-30-2010 06:24 PM
150ford
2009 - 2014 F150
84
02-15-2008 11:04 PM
cc322
1999 to 2016 Super Duty
04-10-2006 06:53 AM
Quick Reply: 2018 F150 King Ranch or Platinum 6.2 L
