Someone said the "C" word (Cams)
When the 6.2L first came out, the lead engineer from Ford came on this forum
https://www.ford-trucks.com/forums/9...as-engine.html
"I can only compare the 6.2L in SD to the 6.2L in the Raptor. It is essentially the same engine other than the cams (slightly less overlap for a smoother idle)."
My question is this. Has anyone here installed aftermarket cams on their 6.2? I have been banned from bringing up the "H" word.
I searched various threads. Maybe it is here somewhere. I am certain Competition Cams will make these. .....Low end torque....easy-to-install....
Performance Mods
This truck will typically be used for errands, vacations (I usually rent a trailer which my F-150 cannot easily tow). I also race cars, will trailer those around. I really like the looks of the Super Duty trucks.
This engine has been out a while and it appears that the common mods are: hand-held or mail order tunes, muffler replacement and straight pipes. I wanted to hear from people who tried other mods. I live at 6200' elevation, so I have to be careful.
I live near Army bases, and these guys modify the heck out of the Dodge Hemi/Chevy LT1 trucks. I am learning that forum members are not modifying the Super Dutys near as much.
The f150 supercharger will work on the superduty with custom tuning. Your looking at 10 grand by the time your finished unless the price on the supercharger has come down some. There is thread in this section with links and a discussion. What gears does your truck have? That might be the biggest bang for your buck.
Short Blocks, Complete Engines, $5100 installed....
Thank you, Nice website. $1200 for cams, $5100 installed with some other stuff
Seems to have a racing focus. Short block,complete engines.
Fuel Pumps, Oil Pumps and 160 deg Thermostats
I have a 2012 Raptor supercab with headers and a Whipple supercharger. The engine really is amazing but it dies once in a while. I would not cam my F250 if it will cause this symptom. I am actually planning to get a SD and make it fast. It will never be as fast or nimble as a Raptor but the Raptor breaks a lot. (power steering pump, steering rack, IWE, Axles) And I want 40 in tires. I do love the turning radius of the Raptor and the suspension at high speeds.
But if you read FRF the problems I have had are very common without forced air. I don't drive my truck particularly hard. It's just very poorly designed. Amazing suspension but everything else is the same as a normal F150. How can you expect stock steering and drive components to stand up to way more travel, steeper control arm angles, huge tires, and much more power? It's just made to go fast. It's not made to actually wheel. I want a better combo of both. I have considered diesel but I want the truck to be as light as possible. And I'm really happy with the Supercharged 6.2. Power and sound
