My daughter's 4 year project and counting
#48
Also, split rear window, 60x5 AC (60 miles an hour with 5 windows!)
#49
That is an attempt (i think) for a ram air fresh air input to cab. Came from manitoba, summers are hot, more air is better. As you can see thats NOT going back on. In fact, im putting in a climate control, WITH the original heater box, that should work better...automaticaly bypass heater core when interior heat not needed...(the manual valve always failed, stuck, passed).
#50
#53
So now got the grill done and on (temporary as the valence goes under it first, but no safe place but on the truck!)
Hood stripped only
And then navel jelly, rust all removed, only two spots!
Front all primed and ready for block sand and paint!
And yes, this is my paint bay, 30’x60’ shop! 54 gets moved to driveway when painting!
Hood stripped only
#54
#55
#59
#60
Naval jelly
Hood stripped only
Hood stripped only
