1952 12 Volt Conversion (With Pics and Part Numbers)
The modern 4-terminal solenoids are looking for voltage on the "S" terminal to crank. I don't see how the 1-terminal starter button can possibly do that, it grounds the wire running to it when pushed. Can't say about the Cole-Hersey type solenoid.
Scotty, very clever idea on the instrument regulator mounting. I had that type (Ford CVR) and found the gauge needles moved around a lot as it cycled to make 6 v.
NAPA calls them instrument regulators, their part # is IR-1. Not that I particularly recommend theirs, they are not super quality, and they've gone from $15 10 yrs ago to $62 now?!?! Your Ford dealer might be a better source, but I don't have a p/n. Or if there's a boneyard with 60's Fords in it, grab one out of those. Personally, the electronic regulators look better to me.
Jim, I looked up my eBay history and it is listed as 1966-1969 Ford Lincoln Mercury Instrument Panel Voltage Regulator Stabilizer U.S.A.
Ross is correct the the larger converter I used for my wiper motor is probably best. If I have any trouble with the small one I will just tap into the large one. I already had the small one on hand so I used it.
The small one "I think" cycles between a range of voltage and the large one is a steady 7 volts.
harleymsn
17
07-13-2017 05:05 PM
ktgovols
11-26-2015 10:06 AM
WingingIt74
08-29-2014 10:09 PM
Old Reliable
09-09-2011 11:33 AM
