Two Issues
Old Feb 18, 2017 | 10:55 AM
tvliftcabinet's Avatar
tvliftcabinet
Two Issues
Hoping you guys can helo with two issues:
1. Rear turn signals work but both fronts stopped working. When I put either the left or right blinker on, the guage flashes both left and right simultaneously like the hazards are on. Is this indicative of a burnt bulb?
2. Oil bath filter will not seperate. Has the original labels so I dont want to soak the entire canister. Is there a lock or a secret to sperate the two halves?
Thanks in advance.
Old Feb 18, 2017 | 12:35 PM
My1964ford's Avatar
My1964ford
Thanks in advance.
I might be be able to help on question 1. If they both flash simultaneously then you might want to check and clean any grounds. Mine used to do the same thing until I tightened up one of the headlights and now both blinkers work correctly.
Old Feb 18, 2017 | 01:00 PM
daveengelson's Avatar
daveengelson
Not familar with the oil bath, suggest try an advance search on topic and narrow field to the 61-66 forum. Brief look-see came across a link may find helpful? There should be a 'how to' convert oil bath article in the 'tech' forum, again suggest trying running an advance search on topic?
https://www.ford-trucks.com/forums/1...-question.html
As My1964ford mentioned, tend to find many electrical problems due to a poor ground? Suggest check to ensure the connections from dash harness to instrument cluster are attached correctly, particularly if worked on recently. Make sure to clean ground surfaces before securing the ground wire, with exterior connectors, I use a dab of dielectric grease.
Posting a link to another thread where member posted diagrams post #4 may find helpful?
https://www.ford-trucks.com/forums/1...e-diagram.html
Old Feb 19, 2017 | 06:16 PM
66v8baby's Avatar
66v8baby
oil bath answer
Just flip it upside down and gently run a flat blade screw driver around the perimeter between the outer and inner shells. It should be all that's necessary to break the seal. I just did this a couple of days ago for the same problem.
Old Feb 26, 2017 | 02:51 PM
tvliftcabinet
It feels like there is a locking mechanism as the 2 pieces have a spring in between. Still havent gotten the 2 pieces apart but the spring makes me feel like there is a trick to seperating them?
Old Feb 26, 2017 | 05:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's no spring, the upper half is stuck to the lower half, usually caused by dirty varnished oil. It probably hasn't been apart since Reagan was prez.
Old Feb 26, 2017 | 05:42 PM
tvliftcabinet
But I can push on the top and it goes down 1/4" and springs back
Old Feb 26, 2017 | 05:47 PM
NumberDummy
It's stuck together, a common problem w/an oil bath that hasn't been taken apart in a long time.
Old Feb 26, 2017 | 05:54 PM
yankbs 66f100's Avatar
yankbs 66f100
If I remember correctly, the truck was running, and oil spilled out of the cannister when you removed it from the carb. If it has been a while since it was cleaned, there is a lot of grit and grime between the top and bottom halves. Turn it upside down, and spray WD 40 around the lip, this will loosen, and clean out the grit. Like Bill said, it's a common problem with the oil bath filters. Put up a pic of the cannister if you can.
Old Feb 26, 2017 | 06:24 PM
tvliftcabinet
Pics
Here are pics of the truck: 1966 F100, 240, all OEM.
Old Feb 26, 2017 | 06:31 PM
yankbs 66f100
Great looking truck, and engine compartment.
Old Feb 26, 2017 | 06:37 PM
tvliftcabinet
Thanks
Straight outta Kansas a month ago. One owner for 41 years and then the ford dealer bought it back and kept it shelved for 10 years.
Original paint but will go for a frame off in about a year to preserve it as it needs no patch panels just some surface...
Old Feb 27, 2017 | 09:48 AM
NumberDummy
Not quite.
Hubcaps are 1973/77 E/F100; 1975/77 E/F150: D3TZ-1130-B
Pic: Correct 'outie' hubcaps for 1965/66 F100 are TYPE 2: C4AZ-1130-A
Pic: Correct 1966 F100 (optional) wheel covers are TYPE 5: C6AZ-1130-G
Pic of the holes in the doors, truck originally came with Western Jr. 'Swing-Lok' mirrors.
Old Feb 27, 2017 | 10:10 AM
tvliftcabinet
Gottem
I have the original mirrors and I have the original rims/tires including the hubcaps and spare.
Nash202033
Garage & Workshop
Feb 26, 2015 07:43 AM
A/Ox4
Jul 10, 2011 10:08 PM
alconk
Nov 16, 2008 10:05 AM
late70sfordnut
Offroad & 4x4
16
Feb 15, 2008 11:01 PM
