Thinking about putting DELO in my 300 next oil change
Oil & Lubrication - Ford Truck Enthusiasts Forums
https://www.bobistheoilguy.com/forum...s.php?ubb=cfrm
There are the two best battle fields for the oil wars...
You can use HD engine oils if you do not have a catalytic converter.
Comparing Gasoline and Diesel Engine Oils
Re: Delo 400
Thanks for link. We did not change over to unleaded gasoline until 1986 here. No problems with a 1978 F-100!
When the 300 was reconditioned the engine rebuilder recommended Penrite 40W-70! I baulked at that recommendation and went to Penrite 20W-60 instead. The Delo 15W-40 is a good compromise.
TallPaul
25
10-26-2005 10:41 AM
icelander
04-13-2002 05:12 PM
