To Guys Towing 5th Wheel Trailers, a question...
Maybe all you experienced 5th wheel guys can assist....I figure what better place to ask then the forum of Super Duty trucks.
5th wheel is obviously the way to go for a better and safer towing experience, having the weight directly over the axle, rather than the weight and pivot point at the receiver hitch.
Has anyone ever seen an RV Travel Trailer but with a 5th wheel hitch? I don't like 5th Wheel RVs because of the MASSIVE front portion of the camper hovering over the box. It's just a big air pusher. Yes, I understand that's free space the RV manufacturer uses over the pickup's box, and the overall truck/trailer is shorter than with a receiver-pull Travel Trailer. I just want a nice towable Travel Trailer but with the benefits of a 5th wheel hitch. For the visual think flat bed equipment trailer contractors use to haul their bobcat and backhoe, but in RV Travel Trailer format. Would be a better pull, better ride, better in cross winds, better with semis driving by. I know the Super Duty has trailer sway control, and I know it's difficult to push one of these trucks around, but peace of mind is something, right?
Thoughts?
Thoughts?
Forest River makes a "Work and Play" line that includes 5th wheels. These roof lines do not step up at the truck like most other 5th wheels do.
https://www.rvtrader.com/dealers/Sco...8RLS-120519923
on
I actually think there is a market for these kinds of setups. You get all the strength and control of a gooseneck setup with a travel trailer profile and extra trailer bed space for toys and such.
maybe
if you are looking for a GN trailer with living spaces and some room to bring toys you can take a look at living Quarters horse trailers (stock types, 2016 merhow alum star)
They will be heavier than regular travel trailers....but also a lot stronger.
If you do look for them limit your search to stock types as you would not want the horse partitions (since they add weight an cost)
I gave up 5th wheel and got a travel trailer. I wanted to keep a camper top on my F350 crew short bed with a truck vault in it and could not do that and tow a 5th wheel. We ordered a 40 ft Jayco Eagle travel trailer and I was all set to order a Propride since I was sure it would be needed with such a large travel trailer and about 1300 lbs tongue weight. But the new travel trailer arrived surprisingly quickly and I had not ordered the Pripride yet. I had to tow it 60 miles home with just my Weigh Safe hitch--no weight distribution hitch and no sway control. I thought I would just take it easy on the drive home. Knock me over with a feather. At 65 to 70 on the interstate it towed level and with absolutely no sway even when I passed or was by by a semi. I may still eventually go for a Propride or something similar just for the safety margin. But I have to tell you I am not sure it is needed. I emailed etrailer and about the issue and they flat said that they doubted that I would need anything other than my Weigh Safe on a new 350 towing a 10,000 lb travel trailer.
I do have 16 inch tires and the trailer and I am sure that helps. So I am going to tow some more with my Weigh Safe before I decide. But I seriously doubt that you will be unhappy with the towing experience with a plain old regular hitch travel trailer.
